Sky front shackle flip
Old May 10, 2020 | 12:28 PM
crucialprospect's Avatar
crucialprospect
Got the kit, no instructions. By looking at the pictures on their website, I got the front installed and I believe it’s accurate.
their instructions are for the superduty springs and I’m using the obs ones, this is relevant because now I’m at the rear shackle. Does the factory shackle get trimmed? I saw a template where they re-drill the whole an inch higher and cut off the lower section, but honestly I’m not sure what I’m supposed to do regarding the rear. Any help would be greatly appreciated!
Old May 10, 2020 | 02:56 PM
Franklin2's Avatar
Franklin2
Here's the instructions.
https://cdn.shopify.com/s/files/1/07...ugnose.pdf?985
Old May 10, 2020 | 03:08 PM
crucialprospect
Thanks. Saw that on their website but it’s specific to superduty springs
Old May 10, 2020 | 04:51 PM
Franklin2's Avatar
Franklin2
Well, I read it a little bit. From what I get out of it, you have one measurement from the factory rear hanger to the new front bar for OBS springs, and a longer measurement for the superduty springs. You just measure and position the front hanger assembly accordingly if I read it correctly.
Old May 10, 2020 | 04:53 PM
Franklin2's Avatar
Franklin2
They say use 51.5 inches for the obs spring, and 55.5 inches for the superduty spring. Is that correct?
Old May 10, 2020 | 05:11 PM
crucialprospect
Sounds about right, but I was worried about how much of the factory rear shackle hanger hangs below the hole and if it would impede travel.
pictures are worth a thousand words
Old May 10, 2020 | 06:02 PM
Franklin2's Avatar
Franklin2
I would get the grinder out and take a little bit off.
Old May 10, 2020 | 06:04 PM
Franklin2's Avatar
Franklin2
From the reading I was doing, they were more worried about the angle of the shackle, and that it went the correct direction when the spring compressed. I guess as long as when your spring goes into droop, the shackle doesn't flip accidentally to the front.
If the suspension is hanging in the picture, that angle will get better when you put some weight on it.
Old May 10, 2020 | 06:45 PM
crucialprospect
That’s full load in the front suspension, I may get back under and verify the length.
I must say, Initially, I’m impressed. It does ride smooth, but not sure if that’s due to the slighter lower capacity of the front springs.
the reason I didn’t go superduty springs was the much lower weight capacity, of course they’d ride smoother, but lose the load rating
Old May 10, 2020 | 09:14 PM
Franklin2's Avatar
Franklin2
I have forgotten what you originally had, but if you had the ttb springs on a straight axle, I have heard they ride very stiff. If you had lift springs under it before, I have them and I can tell you they do ride rough also. There is a bridge near me that has a bump in it, and when I hit it in my truck my rearend leaves the seat. That doesn't happen on any of my other vehicles.
0500757Arf
38
Jul 6, 2016 09:05 PM
crazed87bronco
Apr 11, 2013 11:23 AM
JSV
18
May 23, 2012 12:34 PM
antunez13
Dec 10, 2007 01:23 PM
62uni4x4
Offroad & 4x4
May 13, 2004 09:31 AM
