Tire pressure help
Old May 8, 2020 | 07:49 PM
207bowhunter's Avatar
207bowhunter
Tire pressure help
I have a 2019 f350 6.2 long bed. I just installed 295 65 20 toyo at3 tires on it and tonight had the first opportunity to take it for a lengthy ride. The installer has my fronts at 63 lbs and rears at 81 lbs. Comparing it to the Michelin at i took of the ride seems a lot harsher and at times a little squirrelly. My question is what is a good pressuer to run this truck at? I dont really tow anything nor have a significant amount of weight in the bed. Any help would be great
Old May 8, 2020 | 08:35 PM
Blair Evans's Avatar
Blair Evans
I have my front set at 50lbs and rear at 60lbs. Had to change the tire pressure numbers in Forscan to get rid of the low tire pressure light.
Old May 8, 2020 | 09:05 PM
jrwinger's Avatar
jrwinger
I run 45 front and 40 rear when unloaded. changed values in forescan to get rid of the low-pressure light.
I'm running 37x12.5 ridge grapplers and the ride is MUCH better with the lower pressure.
Old May 8, 2020 | 09:11 PM
Mikelikesit's Avatar
Mikelikesit
Yea 80 is way too much for running empty. I mostly commute. With the stock 20" Michelins I run 65 front and 50 rear. Experiment.
Old May 8, 2020 | 09:12 PM
207bowhunter
How far can i drop without effecting the warning system
Old May 8, 2020 | 09:54 PM
Brian Exline's Avatar
Brian Exline
This 48F/42R
Old May 8, 2020 | 10:05 PM
TeddyD's Avatar
TeddyD
You should be fine at 55psi all around. You can always adjust the thresholds using forscan. My buddies 19 alarmed at 50 psi but that is where he likes to keep them so he always got the warning. I changed his thresholds for him to get rid of the idiot light. The tears might alarm at 55.
Old May 9, 2020 | 06:17 PM
samuse's Avatar
samuse
Download the Toyo load and inflation table, weigh your axles, divide by 2, and that's what they should be.
I always run my fronts at what the door sticker shows, and the rears about 5-10lbs over what the load and inflation table shows for my weight in case I pull a small trailer or something.
When I pull heavy, I inflate all tires to max.
Old May 10, 2020 | 07:35 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Around 60 psi is what i have seen is lowest stock setting some where in there
Baldicon
Nov 16, 2017 12:42 PM
sumbuddyloanmea.10
All Things Towing
May 26, 2010 05:13 PM
jonesuh
Jul 30, 2008 09:06 AM
garymake
Dec 13, 2002 03:10 PM
RBrendel
Jun 7, 2002 05:26 PM
