Temp sensor problems
Old May 7, 2020 | 10:44 PM
Thurston Jamie's Avatar
Thurston Jamie
I mentioned this a few weeks back when I was working on the steering.
I have a 1964 F-350, I get no temperature reading on the tempo gauge. All other indications work. If I ground the wire to the engine block the gauge goes to full hot. Tonight I received the temp sensor I order using the P/N to cross reference provided by Number Dummy. I tried 2 from NAPA and nothing, now this one that is specifically listed for my truck nothing. I am getting frustrated thus should be an easy fix. I have meter the wire, pulled the dash and swapped the gauges, and I can't find anything wrong at all. The probability of getting 3 duds in a row is near zero I would think. Any ideas what I am missing here.
Thanks
Old May 8, 2020 | 04:51 AM
User 71024's Avatar
User 71024
Thanks
Put a test light on the hot side of the gauge, the light should flash if the gauge regulator is good. Then with the sending unit disconnected check the sender side of the gauge, you should still get that pulsing light. then go to the sender and check the wire there. Should still be the same.
Eric
Old May 8, 2020 | 09:29 AM
6t6merc's Avatar
6t6merc
EricJ is referring to the instrument voltage regulator. He has recognized that because the sender, gauge, and wiring are good, the voltage regulator must be the problem. Are the other gauges working properly?
Eric
Old May 8, 2020 | 09:37 AM
Crop Duster's Avatar
Crop Duster
It is entirely possible to get three bad ones in a row considering they were probably made in China or Mexico.
The best way to test the gauges is to use a 10 ohm and a 73 ohm resistor. These King Seeley type gauges just measure resistance to ground at a nominal 5 volts. It makes no difference whether it is fuel, oil pressure or temperature they all work the same.
Disconnect the sender and connect the 10 ohm resistor to ground in place of the sender. The gauge should read to the high mark. Connect the 73 ohm resistor the same way and the gauge should read to the low mark.
If the gauge passes the test the sender is bad. And if it doesn't and the other gauges are working you need to trace the wiring.
You should never ground the sender wire to see if the gauge is working because if the ICVR has gone bad and is putting out 12 volts you can ruin the gauge. Actually on later models with printed circuit instrument wiring you can burn out the entire printed circuit .
Old May 12, 2020 | 08:02 PM
Thurston Jamie
Ok I used a test light as detailed by EricJ everything is as he detailed, flashes at hot, flashes on the sender side, flashes at the wire.
All other gauges work perfectly.
jplinville
Aug 13, 2016 05:05 PM
Shane Carruth
May 29, 2016 04:17 PM
DaytonaTunnel
Jun 19, 2011 03:56 PM
frankyford
Aug 2, 2009 03:17 PM
10-4 Crash
1983 - 2012 Ranger & B-Series
Feb 8, 2007 08:54 PM
