Temp gauge hasn't been working, so I replaced the sensor. Went to turn the key, and noticed the gauge actually go backwards...and after 10 minutes, not heading in the right direction.
Is it possible that the guy that swapped engines for me could have accidentally cut wires and hooked them up in reverse, causing the gage to read the wrong way?
The sender forr the temp gauge is a single wire (nothing to reverse) it's probably red/white stripe & just pulls off of the sender. What does the gauge do when you remove the wire from the sender?
What does the gauge do with key on when you ground the wire beside the sender, it should read full hot
Typically there is a Temperature Sender for the dash gauge and a Engine Coolant Sensor for the pcm. The sender is usually a one wire unit and the sensor has two. To make it more interesting I believe the sender comes in two flavors; one for a gauge and one for if you just have an idiot light. You are probably looking/working on the wrong one.
Yes you replaced the wrong item. You replaced the ETC for the computer.
The sender for the gauge has one wire. Do not ground the wire for the ETC sensor and computer, only ground the one wire for the sender.
I replaced the coolant temperature sensor. It has two wires. When the key it turned on, the gage drops, and when the engine is at operating temperature, the gage does not move.
I hope that clears that up some...
It is perfectly clear to me that you replaced the wrong sensor as pointed out by subford.
Ok, I now have the right part replaced, and the gauge seems to be operational, but doesn't run much higher than the lowest mark in the normal range, even after a run through town and back.
I know that with the original engine, I had changed the thermostat to the 160 degree version, because of the triple digit summer heat in Utah. I had to do something to keep it from overheating, and it worked. Now that I'm living in PA with cooler temps, and working with the replacement engine, I'm not sure which one is inside. So, only as a precaution, and to know for sure what I have in it, I'm going to swap it out for the 195 degree version, and see how it goes.
At least I know the gauge now works...right?
I hope to get this sorted out by Monday, and get a good baseline of where the gauge needs to be under normal operation. I have a long list of small jobs to complete on this truck before Winter sets in. I don't feel like having it break down and then park it on the side of the house until Spring happens, like I've done each year since moving here.
