08 f150 P0138 code
Old May 7, 2020 | 04:21 PM
Ace79's Avatar
Ace79
08 f150 P0138 code
I replaced o2 sensor and both catalytic converters code still comes up.... I reset all codes and light stays off and then comes on after 50 miles
Old May 7, 2020 | 08:02 PM
steve(ill)'s Avatar
steve(ill)
You may be looking at a broken wire or burnt wire... Look where the wires route along the frame and see if anything is near the muffler or rubbing a bracket.......
P0138 FORD - O2 Sensor Circuit High Voltage Bank 1 Sensor
P0138 FORD Possible Causes
Faulty Rear Heated Oxygen Sensor Bank 1
Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
Intake air leaks Exhaust gas leaks Inappropriate fuel pressure
Faulty fuel injectors
Read more: https://www.autocodes.com/p0138_ford.html
Old May 7, 2020 | 08:14 PM
Ace79's Avatar
Ace79
02 sensor
is there a possibility a bad catalytic converters could ruin a new o2 sensor, I checked wiring
Old May 8, 2020 | 06:04 AM
projectSHO89's Avatar
projectSHO89
That was some expensive guess work.
I'd HIGHLY recommend using Ford's documentation instead of generic things posted on the internet when dealing with Ford's fault codes. The above is rather "not very useful" in this case as it tries to apply to a wide variety of manufacturers.
The P0138 DTC indicates that the voltage sensed by the PCM for B1S2 exceeds 1.5 volts, usually due to a short between the signal line and vehicle power. The short could be in the sensor itself, the wiring harness, or the PCM. The PCED has the diagnostic procedure that should be followed.
Old May 13, 2020 | 02:15 PM
F150Torqued's Avatar
F150Torqued
^^^^^^^^ X2
And an OBDII Mode 06 report gives O2 sensor voltage readings to keep you from having to shimmy under your truck with your VOM.
NotEnoughTrucks2014
Apr 29, 2018 08:28 AM
geta4x4
Feb 28, 2009 06:56 AM
93truck
Jun 15, 2006 09:53 PM
softball10
1997 - 2003 F150
Sep 26, 2002 06:06 PM
