Sponsored by: Real Truck
insulation panels
Old Oct 16, 2003 | 07:02 PM
sprbeast's Avatar
sprbeast
insulation panels
i just put in the drivers and passenger side insulation panels from the excursion. saw an article at the dieselstop about it and tried it. well worth the money. i first noticed how quiet my brothers excursion was and didn't know why. i never thought it would make that much difference after seeing where they go but it is nice. not as quiet as his truck but i am working on it. just thought i would let you know my experience. it only took about (15 minutes to do it)
Old Oct 16, 2003 | 07:50 PM
Yeti's Avatar
Yeti
Good idea, what did the panels cost as compared to dynamat?
Old Oct 17, 2003 | 11:23 PM
sprbeast's Avatar
sprbeast
i got them for cost but i believe they would be about 50-60 bucks otherwise. just a note i also upgraded my cupholders in my 2000 with the current style also an excellent idea found over there. i think that would be around 40 bucks too. the guy who posted that article said his didn't quite match but mine is spot on.
Old Oct 18, 2003 | 12:38 PM
lugnut's Avatar
lugnut
Where do the insulation panels go?
mike
Old Oct 18, 2003 | 03:40 PM
99f350sd's Avatar
99f350sd
give some part numbers please
Old Oct 18, 2003 | 11:12 PM
sprbeast's Avatar
sprbeast
the passenger side goes from the bottom of the glovebox area back to the firewall and the driver side from the bottom of the dash back to the firewall but it has a slit in it to wrap around the brake pedal. they are black plastic with thick felt on the top side. you need to connect them with the plastic push pins used in autos (not supplied) and an existing bolt/nut on each side. i will post part numbers tomorrow after i find the paper.
Old Oct 19, 2003 | 12:24 PM
sprbeast's Avatar
sprbeast
here are the part numbers
yc3z 78046a25 aa..........$27.36
yc3z 78046a24 aa..........$22.46
in dash cupholder (current style replaces old style with foam fingers)
yc37 2513560 cab.......$51.33 (this is the number for prairie tan color)
Frost_26
1978 - 1996 Big Bronco
May 1, 2010 09:17 AM
amdc5c5
Apr 12, 2007 01:43 PM
tkd
Garage & Workshop
Feb 21, 2007 05:21 PM
abmitchell
Paint & Bodywork
Jun 20, 2006 10:48 PM
tacson
Apr 19, 2005 03:37 PM
