Ignition nightmare solved
Old May 7, 2020 | 09:36 AM
NOMAD74's Avatar
NOMAD74
Originally Posted by jfmaz
Don't quit now - you'll waste the lesson learned and time fixing things up. Can't count the number of times I've destroyed things during the "learning curve". If I live long enough, I'll be one smart guy when I die (but probably won't live long enough for that to happen).
I'll keep at it. Got myself a welding blanket yesterday. As you can see in the pics I burned some holes through the metal. Going to try and fill them in with small MIG bursts and then grind them back. This is turning out to be a bit harder than I thought......but I'll keep at it.
Old May 8, 2020 | 05:59 PM
NOMAD74's Avatar
NOMAD74
Thank God for grinders. Made a little progress. Ugly as hell.
Old May 8, 2020 | 06:24 PM
jsc83's Avatar
jsc83
One trick I learned that helped with the burn through is to use a copper backing plate. The weld will not stick to the copper and it acts as heat sink to reduce burn through.
The professional ones are a little expensive, so I used some left over 1/2 inch pipe and hammered a dowel into the end. I then cut the pipe and hammered it flat. I made several in different angles and lengths to get into hard places.
Just hold it behind the seam while you are welding, but be careful. It gets wicked hot. My hand always seems to creep up the wood to the copper part to make sure it's tight against the metal and I end up getting burnt.
It doesn't eliminate the burn through, but if you can get it flush, it helps quite a bit.
We all started somewhere. Keep going. Weld - grind - repeat.
Old May 8, 2020 | 07:21 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by robertrpeak
Yeah, even some of them are made in China......Mexico....Canada.......
Well, out of the 41 years I was a Ford parts man, only once did I see a Ford package say Made in China. Mexico, Canada, etc. true. But the majority made right here in the good ol' U.S.A. Ford warranties their parts. So they make sure whatever country makes the part, makes it to Ford's specs. Which China does not care about.
Old May 20, 2020 | 03:20 AM
NOMAD74's Avatar
NOMAD74
It ain't purdy, but it's coming along.
Old May 24, 2020 | 09:33 PM
NOMAD74's Avatar
NOMAD74
More progress today. Man i'm slow. Hopefully tomorrow I'll get to grinding.
Old May 24, 2020 | 10:02 PM
jsc83's Avatar
jsc83
If your welding is anything like mine, the grinding will lead to another round of welding to get all the spots I missed.
Looking good though. Keep at it.
Old May 25, 2020 | 03:24 PM
DirtyFerd's Avatar
DirtyFerd
Not sure what kind of welder you have. If you have the ability to put a gas tank on it, your welds will be a lot cleaner. Not necessarily better, but a lot less spatter
Jodymarshall
Oct 15, 2023 06:31 PM
eclectix
1966 - 1977 Early Broncos
Dec 1, 2019 08:02 PM
66f-100
Oct 5, 2011 04:29 AM
Murray1
Jan 29, 2008 11:06 AM
74F100Ranger
Aug 10, 2003 04:44 PM
