Ignition switch
Old Oct 4, 2011 | 08:05 AM
66f-100's Avatar
66f-100
Ignition switch
My starter has been dragging for a while now. Yesterday, it was dragging so bad the cable going to the starter got so hot that it melted the plastic around the terminal on the solenoid where it is attached. Since i really needed to use the truck to haul something, i went to the garage and robbed the solenoid off of my '72 mustang and off i went. When i got back home, i tried to turn off the truck with the key but it wouldn't stop running even with the key removed. I had to pull the ignition circuit on the solenoid to turn it off. I am assuming that the ignition switch went bad. Anyone else ever have this happen?
Mark
Old Oct 4, 2011 | 03:35 PM
66CustomCab's Avatar
66CustomCab
I haven't, but I think you're on the right track.
Old Oct 4, 2011 | 05:29 PM
Confederate Diesel's Avatar
Confederate Diesel
Your ignition switch is fine.
Your solenoid is fried.
Old Oct 4, 2011 | 07:29 PM
spurredon's Avatar
spurredon
Ditto on the bad solenoid!
Old Oct 4, 2011 | 08:32 PM
66f-100's Avatar
66f-100
I replaced the faulty starter this afternoon. I also bought a new solenoid. As i was tightening all the connections, i noticed that the yellow top coil had melted down overnight and the top fell off. Replaced the coil with another good one that i had laying around. Turns out that along with my melted coil, my Pertronix also fried itself overnight. Put the points and condenser back in, and the truck is up and running again.
Old Oct 5, 2011 | 04:29 AM
camperspecial65's Avatar
camperspecial65
If you want another yellow top coil let me know as I have a few...
- cs65
john jamieson
Nov 3, 2016 02:47 PM
Jrtouchton
Jun 8, 2016 08:24 PM
78fourby4f250
Jul 9, 2011 07:37 AM
muddybrazos
Jun 3, 2011 09:59 PM
datsun147
May 10, 2011 03:01 PM
