ignition problem
Old Aug 7, 2003 | 11:27 AM
74F100Ranger's Avatar
74F100Ranger
ignition problem
I took my grandma to home depot one day in my truck and on the way out my truck would start up and just die as soon as I let go of the key. So finally we got it started. I was screwing around with it today and found out that when i engage starter it starts and runs but as soon as I let off it dies. So I tried starting it and just letting the key go back just enough to disengage starter, it runs but as soon as I let it go all the way it dies. Do I need a new ignition???
Thanks,
Joel
Old Aug 7, 2003 | 11:49 AM
ranger429's Avatar
ranger429
ignition problem
you could need a new ignition switch or it could be a wire that has gone bad,with the key in the run mode check the wires at your solenoid and see if you have voltage
Old Aug 7, 2003 | 12:34 PM
okiebronco's Avatar
okiebronco
ignition problem
im guessing its either the ignition switch or the ignition module box that mounts on the firewall or wheel well
Old Aug 7, 2003 | 12:41 PM
GR8Diesel's Avatar
GR8Diesel
ignition problem
Does this truck have an ignition ballast resistor or resistance wire?
I have had the same experience an older ford and it was the resistance wire had failed. (The resistor is bypassed during starter operation).
Old Aug 7, 2003 | 03:20 PM
ranger429's Avatar
ranger429
ignition problem
originally they did not come with a ballast resistor
Old Aug 7, 2003 | 09:10 PM
thelonerangerxlt's Avatar
thelonerangerxlt
ignition problem
It's a bad ignition switch. The ballast bypass circuit only operates when the starter turns. Since it runs with the starter off, and slight pressure on the ignition switch, the trouble has to be in the switch.
Old Aug 8, 2003 | 02:06 PM
dfisher1's Avatar
dfisher1
ignition problem
All,
I was under the impression that the coil had two different voltages that it ran off. 12VDC at startup and 9VDC continuos or running.
It was my impression that his was controlled by the DuraSpark box? Yeah, the signal's from the switch to the box. So twelve volts from the switch tells the box to send 12VDC to the coil. No twelve volt signal, it sends 9VDC to the coil?
Am I off base?
KingFisher
Old Aug 8, 2003 | 04:02 PM
okiebronco's Avatar
okiebronco
ignition problem
id pull the module off and take it a local parts house like auto zone or orielys. they can test the module for you at no charge. if its not that THEN spend the cash on a new switch
Old Aug 9, 2003 | 03:13 PM
sparky's Avatar
sparky
ignition problem
Originally posted by dfisher1
All,
Am I off base?
KingFisher
The module actually only controls the ground to the coil.
12 volts from the start relay terminal I during starting to the coil + and approx 9 volts thru the resistor wire during running to the coil +
The module uses two voltage signals from the iginition switch, one is when the switch is in start.....retards the timing a little for better starts and the other is during running which powers up the module.
Old Aug 10, 2003 | 11:22 AM
76supercab2's Avatar
76supercab2
ignition problem
Had the exact same problem on a thunderbird with duraspark. It was the duraspark ignition module. We replace the key switch first and it did nothing to solve the problem. I've seen this problem manifest itself 2 ways. 1: the engine starts with the key in the start position but when you let go it dies. Got around that one because the car had an automatic trans. Put the trans in neutral, started the engine then dropped the trans into drive. The starter cutout shut off the starter motor and we got back to civilization holding the switch.
2. The engine wouldn't start until you let go of the switch. Had to start the engine spinning and then let go to get fire.
Both of these problems were solved with a new module.
Old Aug 10, 2003 | 04:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
ignition problem
You can get the module tested for free at most good parts stores.
