Im needing to replace the shocks on my truck. 2005 Excursion Limited 2WD, not lifted. I was reading on these forums about alot of folks running Bilstein 5100s. Anyone purchased these for 2WD Excursions ? Im having a hard time finding the proper shock for a non lifted truck. Are the 5100s specific to lifted trucks ?
Also, if you have any recommendations for a different shock, please share
KYB Monomax all the way. I had a set go 100K (4WD). rockauto probably has them in stock. They are by far the best bang for the buck. I have Bilsteins on now, and don't dislike them except for the price. They ride pretty well too.
I used KYB KG5397's on my Excursion and like them alot! I also have a stock height, stock tire size 2wd 6.0. Changing the left front is easy, doing the right front is a serious PITA
I recently installed new springs from ATS that gave me about 2" lift and used Bilisteins 4600 on my ex. but mine is 4wd not sure the difference for a 2wd . 5100 are for 2.5-4" lift I believe.
2wd and 4wd have a different mounting type on the top as far as I know?
If you use stock Super Duty springs for a 2" lift on an Ex you will want stock Super Duty shocks as they are the correct length for that application.
In the back you will need to do some measurements and research on shock length to determine if you can get by with an Ex shock or if you need to go to a truck shock. If you go to a truck shock you will need to use the "T" bar from you old shock or purchase a new one as the truck shocks have an open eye at the top.
I don't know about lengths but the 2wd Ex uses a pin top shock and the 4wd has an eye at both ends...
I used Bilstein B6 4600 series on my 2WD stock height.
The part numbers are:
24-185448 fronts
24-185455 rears
The real pain in butt are the front shocks. You need an Allen/hex key to hold the middle stem while tightening the top nut. The nut was a nylon locking nut, IIRC, so you can't just spin the nut down until it makes contact. You have to keep turning it with a wrench while holding that hex key. It's best to have a pivoting ratchet box end wrench or you'll be saying every 4 letter curse word at least 10x.
I'm going to give the Monomax a try in my 2000 7.3L Ex. I have tried the Bilsteins and the Ranchos and while they rode nice, they didn't last very long (12-18 moths of highway driving). I was expecting better given how much they cost.
Bilstein 4600s are valved the same as the 5100s. Only difference is the 5100s are longer.
I have a 2” lift in the rear, so I used the 4x4 4600s because the mounting points are the same on both and are 1” longer.
Front is 1 1/2” taller, so I used the 2WD 4600s. (Works out great).
I tried the 5100s up front, but they were too long. The front mounting points are different between the 2WD and the 4x4.
I don't have an ex...well I do have 2 but they are different...But I had good luck with the 5100's i think they were, aluminum bodied, I now use fox remote res up front. I got good life o the bilsteins before I traded them with a buddy to go back to stock
24-185448 fronts
24-185455 rears
The rear ones are pretty easy.
I have the same Bilsteins for almost 40K miles and couldn’t be happier. When they’re ready for replacement I’ll surely get the same ones.
They provide a firm yet soft ride.
24-185448 fronts
24-185455 rears
I also have a 2WD stock height and have the same Bilstein 4600’s
The have a great ride and handling. Initially they will feel a little stiff but after a few hundred miles they settle right in nicely.
