I just read that all newer 302's had the same 351w firing order. That was what I thought was confusing. I thought only the HO 302s had that firing order.
Probably rad support changed from 302 f150 or bronco.
Or Ford forgot about the 5.8L.
So, since they(302 and 351) use the same firing order, is there actually a sticker that has 5.8L on it, instead of the 5.0L?
Its quite irrelevant, and I'm picky this way, there shouldn't be 5.0L anywhere, since its a 5.8L, just my opinion.
It is just a sticker that I can easily modify to my liking.
Or did Ford just use the same sticker for both 302 and 351?
The sticker part number is the number on the bottom left of the sticker, F4TE-6176-AA, for the sticker you have. Not sure if there is one the has the 5.8 on it. Dennis Carpenter doesn't show anything either.
