Shocks
Old Apr 30, 2020 | 01:51 AM
ulmapache's Avatar
ulmapache
Shocks
Ok...pretty much everything has been gone thru and inspected and replaced if bad in the front end with the exception of the shocks and steering box. Still have a slight wandering problem, especially on rough roads...especially! on rumble strips! Would worn shocks be something that might be the cause? They don't leak, and truck doesn't "bounce" like the shocks are bad... How old they are...who knows. Planning to R+R shocks sometime...if they may be the cause, sooner rather than later...1984 F250 2WD... Thx for the suggestions...
Old Apr 30, 2020 | 02:04 AM
FuzzFace2's Avatar
FuzzFace2
If everything else has been gone thru then why not change them?
Have you put the truck on the rack to make sure the numbers are in spec?
Dave ----
Old Apr 30, 2020 | 08:20 AM
Olds64's Avatar
Olds64
You should also replace or rebuild the steering box. That's going to be one of the biggest contributors to steering slop. Here's a well reviewed supplier:
https://redheadsteeringgears.com/
Old Apr 30, 2020 | 10:38 AM
ulmapache's Avatar
ulmapache
Ok...will swap out the steering gear at some point...again, sooner than later...Redhead does not supply any gears past 1969...and not willing to have truck down while steering gear is being rebuilt...
Old Apr 30, 2020 | 11:03 AM
Olds64's Avatar
Olds64
Here's a good thread:
https://www.ford-trucks.com/forums/1...-question.html
Old Apr 30, 2020 | 01:19 PM
Rembrant's Avatar
Rembrant
No, not likely.
After everything in the steering system has been taken care of, an upgraded steering box is about the only thing that will improve the wandering. Even then, it is not likely that it will eliminate the wander, but it will improve it.
Old Apr 30, 2020 | 05:36 PM
FuzzFace2's Avatar
FuzzFace2
Try Blue top http://www.bluetopsteeringgears.com/ They sent me one for my 81 and I then boxed up and sent mine back.
They sent a paper on how to go about the swap, flushing the system and purging air from the new box and it was stop on.
IIRC it was also cheaper than Redhead
Dave ----
1L243
Aug 11, 2013 01:42 PM
dixiemudder04
2004 - 2008 F150
18
Mar 9, 2010 11:43 AM
97 F250 Heavy Duty
1997 - 2003 F150
Jul 31, 2007 02:03 PM
DYDF250
Nov 19, 2006 11:27 PM
wendell borror
Offroad & 4x4
Apr 7, 2006 09:48 AM
