Breaks
Old Apr 27, 2020 | 01:23 PM
Gjorgjija's Avatar
Gjorgjija
Breaks
1994 7.3 IDI Ambulance, when press break it is a little bit soft and has long path. Is it normal or should be hard and short path of the pedal? Break pads are ok.
Old Apr 27, 2020 | 02:27 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
that is not normal, it is time for a good Brake System inspection.
Old Apr 27, 2020 | 02:31 PM
Gjorgjija's Avatar
Gjorgjija
I am preparing for registration (as we call it here in Macedonia), and need to check it before I do that. Ask that because I have few vehicles and of course every has different brakes.
probably need to discharge trapped air in the system...
Old Apr 27, 2020 | 02:50 PM
tecgod13's Avatar
tecgod13
Bleeding is definitely the first step. May also be a small leak someplace, so check all the lines.
These trucks also have some issues with the brake booster that can cause a sinking pedal.
Old Apr 27, 2020 | 03:27 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I've never seen a Booster cause excessive pedal travel unless it wasn't adjusted right in the first place or a rod was snapped, but I often see fluid leak from the back of the Master Cylinder cause this issue.
Still any leaks at the wheel cylinders or lines or air in the system causes Mushy Brake.
Rear Brakes seem to be the most neglected.
Old Apr 27, 2020 | 05:26 PM
tjc transport's Avatar
tjc transport
i ain't rite
could also be something as simple as rear brakes way out of adjustment too.
Old Apr 27, 2020 | 05:49 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Yep for sure as they are mostly neglected....and self adjusters don't work when they get rusted.
Old Apr 27, 2020 | 08:26 PM
DarkOverCast's Avatar
DarkOverCast
Had this exact issue on my 91, thought it was the booster but adjusted the rear brakes after bleeding everything anyways and it fixed it right up.
Old Apr 29, 2020 | 11:36 AM
Gjorgjija's Avatar
Gjorgjija
Here is video of the problem
Old Apr 29, 2020 | 06:40 PM
tjc transport
i ain't rite
that very well could be rear brakes way out of adjustment.
Old Apr 30, 2020 | 12:20 AM
Gjorgjija's Avatar
Gjorgjija
what is the procedure for adjusting? is it something "special" to do?
Electricowboy
Feb 9, 2020 09:21 AM
Todd Dawson
Aug 27, 2019 08:15 PM
J Scott
May 11, 2018 06:16 AM
fishman002
Aug 8, 2011 11:32 PM
