Fender apron mount
Old Apr 26, 2020 | 11:13 AM
symonds86's Avatar
symonds86
Fender apron mount
On my 73 where the Fender apron monuts to the fire wall behind the front tire is a piece of rubber with one both threw to the firewall then another to the apron. Is this right, the holes and bolts look factory but the tuber peice kinda looks like an old sidewall or something and one sides broke.
Old Apr 26, 2020 | 12:11 PM
440 sixpack's Avatar
440 sixpack
That's correct. sort of crude but it worked well.
Old Apr 26, 2020 | 12:12 PM
symonds86's Avatar
symonds86
Ok thanks at least I'm not missing parts
Old Apr 26, 2020 | 01:24 PM
symonds86's Avatar
symonds86
I was mistaken they are both bad only they one I thought was good just turned to dust when I removed the bolts and the other is just what rubber is let under the washers on the bolts. Does anyone have a pic of what that are supposed to look like or rough measurment
Old Apr 26, 2020 | 06:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Both pieces are available from Dennis Carpenter.
Here's a link to the Ford Parts Catalog showing the illustration
File Type: pdf
Old Apr 26, 2020 | 09:19 PM
symonds86's Avatar
symonds86
Thank you mine look nothing like that even before it crumbled pretty sure it was an old piece of side wall cut out with a chainsaw
truckn1
2004 - 2008 F150
Nov 28, 2010 07:44 AM
mattd17
2004 - 2008 F150
Oct 1, 2008 11:01 AM
Hiflyer746
19
Mar 30, 2007 05:24 PM
Voh
Jan 2, 2007 04:14 PM
06 XL F-150
2004 - 2008 F150
Mar 10, 2006 09:04 PM
