Wrong Coolant in 02
Old Apr 25, 2020 | 10:52 PM
Edward Nunez's Avatar
Edward Nunez
Wrong Coolant in 02
Just got my 7.3 '02 with 248k miles, working my way through all the maintenance work. Realized the radiator says do not use OAT(yellow) coolant but a golden/yellowish coolant possibly HOAT is in it.
Any one seen these with the wrong coolant before and if so what should I look out for when it comes to parts going bad?
Is it a good idea for me to be changing it back to IAT (green)?
Old Apr 25, 2020 | 10:57 PM
ford390gashog's Avatar
ford390gashog
Have seen lots of them filled with universal coolant like prestone. I suggest going back with green or go to elc.
Old Apr 26, 2020 | 02:34 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
02 is filled OE with Ford gold coolant. Zerex Gold G-05 is what I use in my 02. The Mercedes gold is also fine if you have that.
You can use green, but the gold lasts longer and does not precipitate silicates that wear out water pumps near as bad as green. With green you should run a coolant filter.
Or just flush it and use ELC as Herr ford390gashog advised. Flush doesn't have to be OCD levels, gold and ELC mix just fine.
Old Apr 26, 2020 | 03:11 AM
Edward Nunez
Okay took me a little while but I believe I understand. Its just weird that the label on my radiator has a cross on yellow/orange colored coolant. But if the engine manufacturer claims ELC is best then I can't argue. Will be doing the switch to ELC, thanks guys!
Old Apr 26, 2020 | 08:00 AM
SkySkiJason's Avatar
SkySkiJason
COLOR is not the most accurate way to ID coolant type.
Like stated above, ZO5 (goldish) was likely the factory coolant.
That is not a factory label - at least not one I’ve seen....
The best coolant for your truck is ELC (OAT) like CAT EL1, Rotella ELC, etc.
But, you’ll need to do a proper cooling system flush that includes removing the block drains and ‘flushing’ until they run clear.
Old Apr 26, 2020 | 09:59 AM
Edward Nunez
That helps clear it up, if must be a aftermarket radiator or a replacement. Going to see if I can grab the part number. Thank you!
dandy250
Dec 18, 2007 11:01 PM
ha305
19
Oct 19, 2006 05:21 PM
SpringerPop
15
Nov 22, 2005 02:23 PM
fhartell
Jan 1, 2004 06:44 AM
haakeye50
Jan 5, 2003 08:43 AM
