Adhesive
Old Apr 25, 2020 | 09:20 PM
66f250's Avatar
66f250
Adhesive
What adhesive do you guys recommend or have used for gluing the shift **** back on to my shifter arm? My t18/t19 shift **** comes Right off, and is sloppy. The shaft is splined not threaded. Thanks Joe. (1983 f150 4x4)
Old Apr 26, 2020 | 01:23 AM
BigBlue2's Avatar
BigBlue2
I used a two part epoxy in a dual syringe applicator. You don't need a high strength epoxy. I didn't want my **** on my T-19 coming off in my hand. Some use glues with less strength for easier **** removal. I wanted mine to be somewhat permanently glued on.
Old Apr 26, 2020 | 07:41 AM
ozark1's Avatar
ozark1
JB WELD.........
Old Apr 26, 2020 | 10:09 AM
Franklin2's Avatar
Franklin2
The factory used something that looks like melted plastic. I don't know if it's really a melted plastic like GM used to hold their u-joints in, or if it's a very stiff hot melt glue. I had to the take the shifter **** off my bronco II and the manual said use a heat gun to get it off. It came off but like you are experiencing, it kept coming off afterward. I had some PVC pipe glue sitting handy and put some of that on the **** and it seems to have worked. Probably any sort of glue would work.
Old Apr 26, 2020 | 10:47 AM
66f250's Avatar
66f250
I was thinking JB weld would be a good permanent fix. Never thought of PVC glue. I have both. If one doesn't work i'll try the other.
Old Apr 26, 2020 | 07:30 PM
BigBlue2's Avatar
BigBlue2
JB weld will be a permanent repair. The strength is 5000 psi. If you glue all the way around it's never coming off. I used a lower strength epoxy and was spare in applying it. Just a couple dabs will do. Any two part epoxy with a strength of no more than 2000 psi will be adequate. If your **** is wiggly loose you might want to use a bit more to take up any slop. Mine fit tight so just a dab was needed.
JRS2
Aug 28, 2011 11:02 AM
6LPSD
Sep 3, 2010 10:25 PM
rodymartin
1983 - 2012 Ranger & B-Series
Dec 13, 2006 04:32 PM
kevin510
2004 - 2008 F150
Nov 8, 2005 09:12 AM
mikewalsh1
Jul 21, 2005 10:07 PM
