1978 - 1996 Big Bronco
TTB Front End Alignment Shims
Old Oct 16, 2003 | 10:31 AM
willys4x473's Avatar
willys4x473
I,ve got an '81 Bronco(351,c-6,Quad shocks). I'm installing a 4" Superlift w/extended radius arms and lifted rear springs. While I'm at it I figured I'd replace all bushings and the ball joints. What alignment shims should I use. I've heard 2 degrees is correct, but i wanted to double check. Or should I go with the adjustable type?
Thanks
Old Oct 16, 2003 | 11:04 AM
greystreak92's Avatar
greystreak92
I've always been partial to having as much adjustment available up there as possilbe...never know when something is gonna get bent, shifted, etc and if its not bad, you can adjust the shims to compensate at least until you can replace the component.
Old Oct 16, 2003 | 09:23 PM
fatfenders's Avatar
fatfenders
Definitely get the adjustable if you are lifting. I used the 2 3/4 degree adjustables and it still wasn't quite enough.
fastang50
Jul 25, 2025 05:56 AM
granny_rocket
Mar 31, 2016 01:33 PM
ivanribic
Offroad & 4x4
28
Mar 2, 2016 11:30 AM
resto-mod
Feb 4, 2015 01:57 PM
lilrobo
May 3, 2014 08:32 PM
