Adding shims to 10.25 open rear
Old 02-04-2015, 12:54 PM
resto-mod's Avatar
resto-mod
resto-mod is offline
I bought a used locker for my front dana 50 (woohoo) but I want a posi rear to. Can I shim the spiders tighter for a sort of poor mans limited slip until I save the $$$ for a lock rite? I've heared of guys doing it in 9" and 8.8 for years, with good temporary results. The 10.25 shouldn't be any different correct? A couple .005" shims should help her hook posi until the shims wear out?? I don't want to weld, I'm afraid of snapping an axle when I put weight in the bed, and it seems dangerous when towing in my mind, plus I wouldn't be able to reuse my carrier for the lock rite. Thanks in advance!!
Old 02-04-2015, 01:57 PM
Conanski's Avatar
Conanski
Conanski is offline
If your 10.25 is the LS version then yes shimming the clutch packs tighter will improve it's performance.
Dutter
1983 - 2012 Ranger & B-Series
03-14-2011 03:04 PM
Rx7toys
02-13-2005 12:59 AM
t.j.g.
02-04-2005 07:12 PM
Ben242
1978 - 1996 Big Bronco
10-27-2003 06:40 PM
charlez
07-31-2001 05:00 PM
Quick Reply: Adding shims to 10.25 open rear
