1978 - 1996 Big Bronco
Brakes
Old Sep 17, 2003 | 07:55 AM
Sf006's Avatar
Sf006
Brakes
I have a 84 Bronco. The brake light stay's on and won't go out and the brake pedal is really soft. I don't see any leaks. I have bled the rear brakes. I wasn't able to get the front bleeder's to open. When I bled the rear brakes very little brake fluid come's out as the pedal is depressed. The brake's still work but not very good. Do I need a new Master Cylinder? Or does anyone know what would cause this.
Old Sep 17, 2003 | 08:37 AM
Sf006's Avatar
Sf006
Brakes
I just remembered I can hear a noise I think coming from the Master Cylinder when the brakes are depressed.
Old Sep 17, 2003 | 09:01 AM
Trucky18's Avatar
Trucky18
Brakes
you should probubly try to bleed the front brakes, cause if theres air in the lines it will make your brakes soft
Old Oct 17, 2003 | 12:55 AM
54Guy's Avatar
54Guy
http://www.asashop.org/autoinc/dec99/techtips.htm Search for THe Fading Bronco Brake Pedal.
