3d printed replacement for sunglass holder.
Old Apr 23, 2020 | 04:48 AM
DAFBFD58's Avatar
DAFBFD58
Maybe I'm not using the right key words to find it but does anyone have the file or link to the 3d printed gauge pod replacement that goes where the sunglass holder is in the overhead console? I've got a switch panel for my emergency lights that I want to use so I don't tie up all the other upfitter switches.
Old Apr 26, 2020 | 04:42 AM
DAFBFD58's Avatar
DAFBFD58
Nobody knows what I'm talking about?
Old Apr 28, 2020 | 10:27 PM
Parksoffroad's Avatar
Parksoffroad
I have been looking for a replacement sunglass holder / door for the overhead panel without much luck short of buying the entire overhead. You looking to get rid of yours?
Old Apr 29, 2020 | 09:14 AM
DAFBFD58's Avatar
DAFBFD58
No, I am looking for a 3d printed item that gets attached to the inside of the door that houses a gauge pod or switch panel. It has been ages since I saw the original post with this particular item but I don't know what thread it was in.
Old Apr 29, 2020 | 09:18 AM
Parksoffroad
OK, I thought you were replacing your sunglass holder door with the new switch panel. Good luck in your search!
Old Apr 29, 2020 | 09:22 AM
DAFBFD58's Avatar
DAFBFD58
If I go that route I'll let you know.
Old Apr 29, 2020 | 10:04 AM
water_junky's Avatar
water_junky
Something like this: https://offroadalliance.com/products...ount-2015-f150
Old Apr 29, 2020 | 10:07 AM
DAFBFD58's Avatar
DAFBFD58
Originally Posted by water_junky
That was one of the ideas I had. I couldn't remember who made it. Thank you
Old Apr 29, 2020 | 10:18 AM
DAFBFD58's Avatar
DAFBFD58
I was looking for something like this, where I could adjust the opening to fit my switch panel.
DAFBFD58's Avatar
DAFBFD58
Old Apr 29, 2020 | 10:47 AM
Tricon's Avatar
Tricon
Thats just the older version of the same thing he linked you above. Maybe give them a call and ask if you can buy the mount only.
Old Apr 29, 2020 | 10:51 AM
DAFBFD58's Avatar
DAFBFD58
The reason I'm asking for the printing file is I'm looking to mount this switch control up there. Its approximately the same size but the design is slightly different.
ron993's Avatar
ron993
4wd Low
Here is the guy that makes the mount https://swarfworks.com/shop/ols/prod...17-ford-raptor
Old Apr 29, 2020 | 10:55 AM
DAFBFD58's Avatar
DAFBFD58
wonder if they could customize the print to fit the feniex switch panel
Old Apr 29, 2020 | 10:47 PM
Parksoffroad
Those are cool mounts. I wanted to mount the head for my ham radio in the sunglasses holder. Theres enough room in the factory setup that I could mount the head in the sunglasses holder and still be able to close it and make it disappear which was the goal to hide it if you parked in a bad area or something. Before I cut / drill on the factory sunglasses holder door I wanted to get a second one just in case I wanted to go back to stock, so far I cant find just the factory sunglasses door, ford only sells it as a part of the whole overhead console near as I can tell.
