Tank selector switch
Old Apr 19, 2020 | 05:39 PM
Davetruck's Avatar
Davetruck
Hi,
anyone ever have trouble with the tank selector switch< I have eliminated the switch on the dash as the problem. Hoses are fine. No blockages. I am thinking about just getting some brass fittings, a T and two shut offs . I have to at least be able to use the gas in the front tank being as I filled right up when it hit 60 cents / liter.
What does everyone think of this? Anyone know where to get a replacement or a good place to buy brass fittings in Edmonton AB?
Old Apr 19, 2020 | 05:44 PM
Franklin2's Avatar
Franklin2
Ford had several different switching setups on their trucks through the years and for different engines. You did not say what year or what engine you have. Some have a 6 port valve, some a 3 port. Some have fuel pumps in the tanks, diesels don't but still use a 6 port valve. Then you have fuel injection with pumps in the tanks, and a fuel reservoir valve.
They make 3 port brass valves for boating, some people have drilled holes in their floorboard and put two in there to switch the fuel lines depending on what setup they had. But you still have to have a electrical switch also to switch the sending units.
Old Apr 19, 2020 | 05:49 PM
Davetruck's Avatar
Davetruck
Hey thanks Franklin,
It's an 86 with a 300 inline six, it has the pump on the engine, runs off the cam, the selector has a line in from each tank and a line out, the simplest one, it looks like a 4 inch cylinder with only a two wire connector.
Dave
Old Apr 19, 2020 | 05:52 PM
Davetruck's Avatar
Davetruck
I pulled off the line in question from the selector, and put my thumb on the hole, no suction whatsoever, but it kept drawing from the rear tank. I did also check the fuse I suspect it just wont switch.
Probably it's shot, Can they be rebuilt maybe?
Old Apr 19, 2020 | 06:02 PM
Franklin2's Avatar
Franklin2
You just replace the simple switching valves. Not sure if the local stores still carry them. But first, like you mentioned, get a testlight and see if you have power down at the valve when the dash switch is moved back and forth.
If you need the truck running or need to get one of the tanks emptied out, you can take vise grips and pinch the line shut so gas won't go all over the place, and then take the line loose to the engine, and then splice the two lines together with clamps and a short piece of hard line to bypass the valve until you get it fixed.
Here's a link to a brass valve if you wanted to go that route. But you would still use your dash switch to switch the sending units.
Amazon Amazon
Old Apr 19, 2020 | 07:13 PM
Davetruck's Avatar
Davetruck
Good thinking, Thanks, I'll get under there with the tst light, I suspect the valve is somehow shot. I can splice the lines, I might as well just take the selector off and see if I can somehow rebuild it.....
What do you think, I'm happy to make it a manual switch though.
Old Apr 19, 2020 | 07:18 PM
Franklin2's Avatar
Franklin2
Here's one on ebay. You might be able to grab those numbers and do a google search. Or search more of the auto stores. I checked Autozone, they do not carry it.
https://www.ebay.com/itm/New-FUEL-TA...-/171249453850
Old Apr 19, 2020 | 07:21 PM
Davetruck's Avatar
Davetruck
We have one retail store open here right now, NAPA, everything else is closed ,I believe, At least the wrecker is still open , I might just drop in there tomorrow....
Old Apr 20, 2020 | 07:27 AM
FuzzFace2's Avatar
FuzzFace2
You have the supper simple valve.
It pulls from the rear tank normaly and when you flip the switch the valve then moves to pull from the front tank.
First thing you want to do is make sure you are getting power to the valve.
No power then even a new valve will not work.
Use a test lights on the wire to ground.
With the switch 1 way (rear I believe) no power.
Flip the switch (front tank) and you should get power.
If no power you will need to find out why, could the switch or fuse be bad?
If you have power on the wire just replace the valve with a new one.
I would not waste my time with a used one from the junk yard.
My 3 port valve was also bad, I had power to the valve but it would not switch tanks.
Got a new valve off Ebay, wire hook up may be different than what you have, but it now pulls from each tank.
Dave ----
Old Apr 20, 2020 | 07:35 AM
Franklin2's Avatar
Franklin2
All you have to do is go to https://www.napaonline.com/ Go up to change vehicle and enter your vehicle info and then type in fuel selector valve in the search box. I just checked my Napa, like everyone else they carry the 6 port valve, not the 3 port like you need. That link in my previous post is not a exact fit valve, though it would work. You would have to cut the factory plug in off and wire it with a crimp connector.
Old Apr 20, 2020 | 08:44 AM
Davetruck's Avatar
Davetruck
Believe it or not, this is my biggest problem in life right now.
Thanks for the advice
Dave
Old Apr 20, 2020 | 04:48 PM
Davetruck's Avatar
Davetruck
Update,
Used to test light and I do in fact have power right at the clip on the valve, So I just decided to do a manual splice.
I got some brass valves and a barbed T fitting from Gregg Distributors.
That should do the trick , I'll throw that all on tomorrow.
Dave
Old Apr 20, 2020 | 05:30 PM
FuzzFace2's Avatar
FuzzFace2
You said your valve has 2 wires I wonder if someone has already changed it out at some point?
I say this because I thought the 3 port valves only used 1 wire (power) and the unit grounded thru the body on the valve.
That is how my 81 is but guess could be different for 86?
Dave ----
Old Apr 20, 2020 | 06:11 PM
Davetruck's Avatar
Davetruck
I don't think it was ever changed .
AndysFords
Jun 6, 2007 11:50 AM
DAN-D-DIESEL97
Nov 17, 2006 09:40 PM
oldmanbergie
May 10, 2004 04:11 PM
ptrill
Electrical Systems/Wiring
Oct 8, 2002 08:07 PM
Dogdecur
Sep 5, 2002 05:45 PM
