1978 - 1996 Big Bronco
Top Bolts
Old Apr 19, 2020 | 03:00 PM
evan_nugget's Avatar
evan_nugget
Top Bolts
So we've discovered an issue with the Bronco top, specifically how it mounts to the body. The two rear bolts go into what looks like captive nuts that slides on a rail? Why they designed it this way I don't understand. The issue is the nut on the passenger's side has decided it wanted to go on vacation and hasn't let us know when its coming back. No sign of it, I believe its been like that since we purchased the vehicle. Ordinarily I wouldn't care because all the other bolts are in fine, but the top isn't seating properly on the body anymore and its letting water leak into the trunk area, which I don't want because its all carpeted.
The worst part is that I tried taking off the plastic trim but I couldn't access the channel where the alleged nut is supposed to be located. It's sealed on both top and bottom. Anyone with an 8th gen had this issue and know a substitute fix or how to get that sliding captive nut aligned up again properly?
Old Apr 29, 2020 | 11:40 PM
greystreak92's Avatar
greystreak92
If any of the spring nuts on the bed rails decide to go for a dive into the abyss between the inner and outer fender panels, unless you have a really nice magnetic reach tool that you are very adept and NOT getting stuck to the steel walls on the way down, you might as well just go get some new ones and leave the one(s) that have fallen to fall out when the wheel arches rust through enough to let them fall out the bottom of the truck.
I have personally had the top off my 92 (and 93) more times than I care to recall and I have NEVER put an 8th Gen. top back on with more than the two long bolts in the top forward corners and the two in the rear aft corners of the bed rails. Never had a water problem. The guide pins near the after corners can be a B$%&ch to get the top to drop back into their respective holes in the bed but once that happens, the rest should go back and seal well. I did add two very thin (1/8" or even 1/16") strips of UHMW plastic to the bed rails on the '93 to facilitate sliding the top off without scratching the rails. Basically give the top a glide surface to rest on. Be careful though, this makes it VERY easy to slide the top around and if the guide pins are free in the back it will fall and do terrible things to both top and bed rails.
Old Apr 30, 2020 | 04:23 PM
evan_nugget
Thanks for replying greystreak. The issue isn't the spring nuts, we have a full set of them. The issue is in the aft corners. The nuts back there aren't spring nuts, its some other kind of captive nut that looks like it slides in a rail in that "abyss" between inner and outer fender. Our right rear is missing and I can't think of a solution or a way to get it to come back. It's gotta have been that way for a long time cause it looks like the top is warped slightly, it won't sit flat on the bed rail at the aft right corner, there is a slight gap which allows water to seep in if its raining.
I don't know if you've run across this issue before, there's literally nothing to screw that aft right top bolt into, just an empty chasm.
Old May 3, 2020 | 07:59 PM
greystreak92
I see... thanks for the clarification. I missed the "aft corner" part. That is odd and unfortunately, I have never had to deal with one of those going missing. They always seemed to be more "captive" than the spring nuts hence the suggestion to just use the corners. I haven't had a close look at that area of the truck in quite some time as mine is not currently "reassembled". I will take a closer look next time I am in the garage and see if I can determine how mine are attached and/or how one might "fix" the kind of issue you are dealing with. Sorry, I was not more help.
Old May 6, 2020 | 10:19 AM
evan_nugget
No worries, thank you for checking up when you get the chance! Yeah its quite the puzzling issue but we'd really like to get it fixed ASAP!
If the top comes off in the near future I'll post a pic.
Old May 12, 2020 | 08:14 PM
nekkidhillbilly's Avatar
nekkidhillbilly
nutsert mod?
Old May 26, 2020 | 08:17 PM
evan_nugget
For those wondering what I'm talking about, here's visual help:
Left side, with the captive nut piece in there
Yeah, this one said sayonara
johnfin1
17
Jun 11, 2015 02:57 PM
santi2322
Jun 25, 2009 06:45 AM
fordman2895
Aug 3, 2006 02:29 PM
lbianc1
Jul 31, 2005 06:35 PM
lockups
Jul 1, 2004 10:42 AM
