1978 - 1996 Big Bronco
body budhings
Old Jul 27, 2005 | 06:34 AM
lbianc1's Avatar
lbianc1
body budhings
has anyone ever attempted to change the body bushings on a later model Bronco? I have an 89 and I can't seem to figure out how to get the bolts out. I put an impact wrench on the bolts but they just keep spinning. I can't seem to find anywhere to put backup on a nut that may be spinning on the top b/c I don't think I can get to it.
Has anyone ever had to deal with this?
Old Jul 27, 2005 | 04:16 PM
lbianc1's Avatar
lbianc1
Damn....nobody?
Old Jul 27, 2005 | 04:29 PM
slickerthanyou's Avatar
slickerthanyou
Originally Posted by lbianc1
Damn....nobody?
I did my '90 about a month ago just sawzalled the sunabitches off or the bolt heads broke off from bieng rusted took me 4 days!!
Old Jul 27, 2005 | 05:03 PM
lbianc1's Avatar
lbianc1
How Did You Reattach The Bolts If You Cut Them Off?
I Was Thinking About Doing That But I Don't Even Know How The Things Are Secured In There. Is It A Bolt With A Nut On The Other End? Thats What It Seems Like B/c When I Turn The Bolt, I Accomplish Nothing. It Seems Like The Nut Is Turning Too. I Can't Find Nowhere To Put Backup To Hold The Nut.
Old Jul 27, 2005 | 05:28 PM
slickerthanyou
Here are some pics- the front two are on Core support but-You have to lift up carpet and remove the oval covers to get to 6 of them and the last two you can get by removing the rear carpet and threshold by the tailgate. There are 10 total.
I can answer any question you have about these as it's still fresh in my mind.-Bob
Old Jul 27, 2005 | 08:17 PM
lbianc1's Avatar
lbianc1
man i never even thought about just looking under the carpet. thanks i'll give it a shot.
Old Jul 27, 2005 | 08:41 PM
slickerthanyou
I tried soaking mine in WD-40 for weeks but still had to cut them! I also added a bodylift since i had to replace mounts. I used Polyurethane mounts too!
Old Jul 28, 2005 | 07:44 AM
lbianc1's Avatar
lbianc1
speaking of bodylifts. I need to raise my body about an inch. The wheels I put on there (33"x12.5") will rub when I am turning in reverse. Are there any kits out there that I can just get an 1" of lift or should I just get longer bolts and put about 5 washers on each?
Old Jul 28, 2005 | 06:01 PM
MatthewC's Avatar
MatthewC
read your other post: You dont need a lift to solve your rubbing issues.
-matt
Old Jul 28, 2005 | 06:37 PM
slickerthanyou
MatthewC is right- But if you want an inch People have used hockey pucks for this. they don't sell a 1" body lift for us but You can always fab something up.
Old Jul 28, 2005 | 06:52 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Bronco graveyard does sell 2 and 3" kits.
Old Jul 28, 2005 | 06:58 PM
MatthewC's Avatar
MatthewC
Originally Posted by slickerthanyou
hockey pucks .
GAHHH! NOOOOOO!
Old Jul 29, 2005 | 08:53 PM
slickerthanyou
Originally Posted by MatthewC
GAHHH! NOOOOOO!
I wouldn't use them either but know of a few that have with no issues.
Old Jul 30, 2005 | 12:40 PM
BroncoRoadKill
Never seen it nor will I ever do it, but have heard of some people using 2x4s.
Old Jul 31, 2005 | 06:35 PM
chrono4's Avatar
chrono4
if all you need is a inch, youll acomplish part of that with the new bushings, backin in reverse, where does it rub?
