Driveshaft length?
Old Apr 21, 2020 | 11:08 AM
harley7991's Avatar
harley7991
So, it's looking like someone cut the countershaft to fit this transmission with the longer tailshaft. Number on the tailshaft is 2602526.
The transmission has a sliding yoke, as does the countershaft. Seems redundant and this is probably why the carrier bearing walked out of the rubber bushing towards the transmission.
I need help with the following:
1. What transmission is this?
2. Should I get a proper countershaft, or a single piece driveshaft?
Old Apr 21, 2020 | 11:38 AM
rdixiemiller's Avatar
rdixiemiller
Mine has the 3 piece shaft, and has been converted to a slipyoke type transmission.
I've had no issues with my setup, was the splined slipyoke by the center support bearing stuck?
Old Apr 21, 2020 | 12:05 PM
Crop Duster's Avatar
Crop Duster
It is most likely from a car. It should have a tag on it somewhere post that info if it is still there.
The simplest solution is to have a one piece drive shaft made using a slip yoke in the transmission. If you are near Johnson City call Bowman Driveshaft, 423-282-8009
Old Apr 21, 2020 | 12:38 PM
harley7991's Avatar
harley7991
I'm in Knoxville, there's a drive shaft shop here.
I found 2 numbers on the transmission (attached). I suppose the follow-up question is that is this transmission worth making a driveshaft for?
Old Apr 21, 2020 | 01:15 PM
Crop Duster
I don't have a parts manual and my interchange book only goes to 1975. But just from the looks of it it's a type 3:03 with a 77 part number. It is probably worth getting a driveshaft made for if it's working OK. Most of the differences in the transmissions had to do with the tail shaft housing and output shaft. The only problem with a one piece shaft is if it gets over 5 ft.or so long you may have to go to a 3 1/2 inch tube.
Old Apr 22, 2020 | 02:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
RAT-DL // D7TR-GA = Ford type 3.03 3 Speed Manual Medium Duty all Synchromesh Transmission.
Original applications: 1977/79 F100/150 2WD Regular Cab - 300/302 - 116" & 133" wheelbases.
NW 150
Offroad & 4x4
67
Sep 13, 2013 06:09 AM
DustinDLamb
Aug 9, 2006 11:31 PM
cadunkle
1978 - 1996 Big Bronco
Nov 29, 2005 12:21 PM
71_4x4_390
Offroad & 4x4
Feb 11, 2004 10:44 AM
Ryan50hrl
Offroad & 4x4
May 2, 2002 04:09 PM
