I have recently purchased a 2019 f 250 Superduty. I'm running stock rims (18x9 I think)
I want to upsize my tires while keeping my stock wheels. I'm installing a 2.5" leveling kit (front only) and airride on rear.
I was wondering what the maximum tire height and width in inches I can put on the stock rims.
When you research tires and look into the specs, most tire manufacturers list the range of widths for the wheels that are acceptable for mounting a specific size. This should better answer your question on what size tires will fit on the OEM wheels.
Check out customwheeloffset.com. You can search for your year truck, type of lift and what the customers did and how it worked out...with pics.
