Rough Country Leveling Kit
Old Mar 5, 2013 | 05:44 PM
bigal53021's Avatar
bigal53021
Ok. i bought the Rough Country Leveling kit with the 2.5" front and 1" rear. They say that it will fit 35" tires without trimming anything. Has anyone else done this to their truck and do the 35" tires fit?
I dont want to buy a set of tires and find out that i have to trim stuff.
Old Mar 6, 2013 | 07:08 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I have a 2" AutoSpring with 3" rear block (~1.5" rear lift) and run a 295/70-18 Nitto Terra Grappler which measures 34.4"x 11.4" wide on stock 18" rims, no issues. Pics in my garage
Old Mar 6, 2013 | 06:57 PM
bigal53021's Avatar
bigal53021
I made a cardboard cutout of a 35" tire and put it behind my existing tire and turned the wheels. With stock rims the 35" tires will not make it. Now i have another question. How do offsets work with rims? Is a stock rim 0 offset?
Old Mar 6, 2013 | 07:23 PM
NASSTY's Avatar
NASSTY
Stock 18's are 18X7.5" w/ +44mm offset; stock 20's are 20X8.5" w/ +44mm offset. With less offset the tires will stick out further.
Old Mar 6, 2013 | 07:29 PM
bigal53021's Avatar
bigal53021
So if i got a rim that said lets say 0mm offset that means that it would be sticking out 44mm further then the stock ones?
Old Mar 6, 2013 | 07:34 PM
bigal53021's Avatar
bigal53021
or what about a rim that has a -12mm offset. that means that it would be sticking out 56mm from stock?
Old Mar 7, 2013 | 03:23 AM
NASSTY's Avatar
NASSTY
Yes, even more if it's a wider rim.
Old Mar 7, 2013 | 08:32 AM
TheStuffz's Avatar
TheStuffz
but then you gotta look into fender flares. dont want to be taking out your mirror or the paint job down the side when you get that far out!
Old Mar 7, 2013 | 10:51 AM
04XLTRUNNER's Avatar
04XLTRUNNER
I ran a 35/12.5/20 on my stock 2009 fx4 rims with minor rubbing. I had a 2" daystar level kit. Had to barely trim the front plastic valence. And the side lugs on those tires rubbed the upper balljoint housing sometimes when it would flex. It was like that for 90k miles and never caused any problems. Mudgrapplers are a really aggressive tread and have big side lugs too. If you go with a less aggressive tire you shouldnt have any problems.
Old Mar 7, 2013 | 07:34 PM
bigal53021's Avatar
bigal53021
Thanks for all the help everyone. I think i am gonna end up getting the pro comp xteme MT2's 315/70R17. WIth Granite Alloy GV4 Black 17 x 8.5.
Frisbeekev
Apr 24, 2017 01:28 PM
jlillie
Jul 15, 2016 10:25 AM
case_7010
6.4L Power Stroke Diesel
Mar 26, 2009 12:40 PM
tinman12
2004 - 2008 F150
Jun 25, 2006 11:54 PM
TexFx4
2004 - 2008 F150
Aug 26, 2005 07:14 AM
