Sponsored by: Auxito
Alternator pooched?
Old Apr 17, 2020 | 09:59 AM
BruceJeremy's Avatar
BruceJeremy
Alternator pooched?
Hey all, I hope you are hanging in there. Quick question re my 1998 Ford F-150, 4.6. Turn the key and hear a very fast 'click-click-click-click-click-click'. Gauges go screwy when key is all way forward. Tell-tale signs of faulty alternator? Could it be starter?
Any help is hugely appreciated.
Old Apr 17, 2020 | 10:19 AM
Tedster9's Avatar
Tedster9
How old is the battery? 2 years? 5 years? This is always the first thing to check.
Can measure the voltage across the posts but without a load on the battery it won't tell you if the battery is serviceable. It is very common for batteries to to measure 12+ volts at rest, though puke when the current demand is high. Turn the headlights on HI, are they nice and bright?
Turn heater fan, and then measure. Or better take the battery to AutoZone or someplace like that and have it load tested.
If the battery checks out OK then clean and inspect battery and ground cables to block etc and tighten securely. Then measure the charging system voltages for alternator operation.
Old Apr 17, 2020 | 11:10 AM
BruceJeremy
Excellent, I'll give everything a check. Thanks!
Old Apr 17, 2020 | 02:32 PM
BruceJeremy
Got a boost and it seems to be running ok. I'm pretty sure it's the battery. I'll check later with the meter (I'm new to using volt meter....looked on youtube for help with regard to proper usage/correct readings). Learning curve! Thanks for the help.
Old Apr 18, 2020 | 08:50 AM
Tedster9's Avatar
Tedster9
Diagnosing a battery that runs down
This should get you started,
Old Apr 18, 2020 | 02:15 PM
Bluegrass 7's Avatar
Bluegrass 7
The click is the start solenoid releasing then re-operating because the voltage drops when the starter connects.
Very first thing is clean the battery cable connections, then address the battery capacity, then the charging system in that order.
Good luck..
BigBlocker0248
Jun 4, 2016 02:42 PM
Hardman
Electrical Systems/Wiring
Mar 28, 2016 10:49 AM
Gregorri
Sep 27, 2005 03:20 PM
pancake
Nov 7, 2003 11:46 PM
