Proper Alternator?!?
Old May 30, 2016 | 12:26 PM
BigBlocker0248's Avatar
BigBlocker0248
Hey guys! I have a 1989 Ford F-150 XLT Lariat Longbed Pick-Up Truck with the Fuel-Injected 5.8 351 Windsor. It has an aftermarket alternator on there and it has gone bad. Whenever I had gone to the auto parts store, before I could order a new alternator I needed to know which position the alternator plug is suppose to be at for my truck. There is a 2:00 position and a 10:00 position. I want to make sure I get the proper alternator. The old alternator that came off of the truck had a 2:00 position, but I don't know if it is the proper one. I don't know if they made a certain alternator for a Bronco and one for an F-150? Please let me know guys so I know which alternator I need to get. Thanks!
Old May 30, 2016 | 12:51 PM
Encho's Avatar
Encho
The Southernmost Mod
The alternators for the F-150/Bronco are the same, since you already had a 2:00 in there why not use the same?.
Old May 30, 2016 | 01:01 PM
BigBlocker0248
Yeah, but the way the wiring ran to the alternator was all bunched up. I didn't know if it was suppose to be a 10:00, or a 2:00. They are obviously two different positions. I just didn't know if for a reason.
Old May 30, 2016 | 01:33 PM
Encho's Avatar
Encho
No special reason, the innards are the same for both and nothing wrong will happen if you use any of them, just use whatever fits your setup best.
Old May 30, 2016 | 03:06 PM
bashby's Avatar
bashby
Have you considered doing a 3g swap? Im not sure if you have the old external regulator that can be a wiring nightmare or the 2g that has the restangular plug that is prone to catching on fire, but the newer 3g is a huge upgrade.
Old May 30, 2016 | 07:56 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How long does it take to reclock an alternator?
3x 5/16 heads screws, tap, turn, replace screws...
I did it twice last week while screwing around with different alternator brackets on my truck.
Old May 30, 2016 | 08:13 PM
rla2005's Avatar
rla2005
You are a bot, please go away. J/K
I thought the same thing earlier today.
Old Jun 2, 2016 | 08:55 PM
QuantumL0op's Avatar
QuantumL0op
4wd High
I've got a '91 F-150 Lariat, and none of the alternators for the 1991 model at any parts store looked anything like the original. One of my aircraft mechanic buddies finally told me to ask the parts store for an alternator for a '95 F-150. I thought he was crazy, but sure enough it was a perfect fit. Don't know if that helps at all
Old Jun 4, 2016 | 02:42 PM
GNR22's Avatar
GNR22
Go to a junkyard and pull a 3G from a Taurus. It'll be cheaper than a "new" one from a parts store, and won't light on fire like a replacement 2G still will. Clocking one hardly takes any time.
Skier041
Apr 5, 2008 11:11 AM
z 97ford1
1997 - 2003 F150
Aug 24, 2003 07:53 AM
slapshotjn
Sep 5, 2002 08:09 PM
