Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Speedometer cable for 1975 ford C750
Old Apr 16, 2020 | 03:14 PM
Stub1994's Avatar
Stub1994
4wd Low
I’m trying to fix the speedometer on my 1975 Ford C750 391 4V with 5 speed Clark 280 non overdrive with two speed axle. I’m not sure of the axle make but it has a large IH cast into the axle housing. It has a two section cable that breaks in the middle where both sections thread into a gear box. I assume that gear box corrects the speedo for the two speed axle ratios. I need some help with this if anybody has any help to offer it would be greatly appreciated.
Old Apr 16, 2020 | 06:07 PM
85e150's Avatar
85e150
Welcome to FTE!
If the cable is intact, take it apart and look at the cable inside. I think you can get that square cable by itself.
Is there an electrical connection to that gear box? I find all kinds of adapters and gearboxes associated with 2 speed axles, but I can't find one for Ford.
Sounds like your axle was a transplant. Same pattern front and rear? IH may have cast the housing but I bet the pumpkin and internals is Eaton. Everybody used Eaton 2 speeds.
Does it lock up when you drive by a corn field?
Stand by, more help may be by.
Old Apr 16, 2020 | 06:29 PM
Stub1994's Avatar
Stub1994
4wd Low
The truck is all original except the trans​​​​​​. I’m the third owner of it, my grandpa got it off the original owner. Papaw swapped it from overdrive to straight 5 speed cause he logged for a living and it was geared too high for the loads he hauled. I’ve been through 3 or 4 cable inserts and it sheared them off about 3 or four inches from the speedometer. I think my housing has a burr in it cutting my cable inserts. The gear box works fine, and it does have a wire going too it from the high low switch. If I had a part number for that cable housing I believe I could run down one on eBay or somewhere.
Old Apr 16, 2020 | 10:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Rear axle is probably an Eaton two speed, speedometer cable is composed of an upper and lower section that attach to an adapter.
Old Apr 16, 2020 | 11:16 PM
85e150's Avatar
85e150
Are those still available as NOS? I doubt anyone reproduces it.
Old Apr 16, 2020 | 11:28 PM
NumberDummy
Originally Posted by 85e150
Are those still available as NOS? Maybe I doubt anyone reproduces it.
Looking up speedo cables for these trucks is a study in futility, there's a gazillion different possibilities.
I looked at the parts catalog pic to see how the cables are routed, then looked in the text. Threw up my hands in disbelief!
Old Apr 16, 2020 | 11:29 PM
85e150's Avatar
85e150
I looked at the parts catalog pic to see how the cables are routed.
Same guy in charge of bellhousing to engine patterns worked the speedo cables too?
Old Apr 16, 2020 | 11:41 PM
NumberDummy
Somebody who hated his job, passed on the hatred to parts guys who had to look this jazz up. Some parts are almost impossible to figure out.
Old Apr 17, 2020 | 01:01 AM
Stub1994's Avatar
Stub1994
4wd Low
If it’s any help at all, and sounds like it might not be, it’s the upper section that’s bad.
Old Apr 17, 2020 | 01:14 AM
NumberDummy
Is the housing kinked? If not, you can replace just the inner woven steel core. Auto parts stores sell a kit, cut it to length, coat w/a fine film of graphite, install in the housing.
Old Apr 17, 2020 | 06:11 AM
Stub1994's Avatar
Stub1994
4wd Low
It’s not exactly kinked, but it does have a pretty sharp bend in it right where the end for the gauge is crimped on. It has a plastic elbow on it there to protect it from getting a kink but like I said the end looks like it has be bent down pretty hard to get it to screw back onto the back of the gauge. It hasn’t worked for years, papaw probably tried to fix it years ago and give up. I’ve been through 3 or 4 cable inserts and I either cut them too short or they get sheared off at the gauge side in that bend.
Old Apr 17, 2020 | 11:19 AM
NumberDummy
D3HZ-17260-E .. Upper Speedometer Cable - 67" long - Use with Clark models 280/282/285/390 5 Speeds / Obsolete
1974/75 C/CT600/900 // 1976 C/CT600/900 before serial number B00,001.
Additional applications: 1974/79 C/CT600/900 with Clark models 385/387 5 Speeds.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
Old Apr 17, 2020 | 11:29 AM
Stub1994's Avatar
Stub1994
4wd Low
thanks a lot numbers dummy. You’ve been a big help!👍
Old May 27, 2020 | 12:30 PM
Stub1994's Avatar
Stub1994
4wd Low
So I have the speedometer working, now I have a new problem.!😒 The gearbox that corrects the gear ratio for the two speed axle won’t work in low. The speedometer works in high range, despite being 5 mph slow, but when you shift into low you lose the speedometer. Shift back into high and you get it back. I’m having trouble finding the part number for the speedometer gearbox. It’s not the type mounted behind the gauge, it’s on the frame between the upper and lower cable sections.
wavetrain75
Aug 7, 2019 10:41 AM
Nevada51
35
Aug 13, 2018 08:48 AM
Mike George
May 4, 2015 04:58 PM
ph1946
Feb 25, 2008 09:43 PM
NoMo
Jul 20, 2002 07:40 AM
