Speedometer Correction advice needed
Old Aug 1, 2019 | 06:19 PM
wavetrain75's Avatar
wavetrain75
I swapped the rear axle on a '49 F-1 with the predictable result. How are you guys correcting your speedometers? Seems to me there are companies making gearboxes that thread to back and correct the reading. Original axle was 4:29, new one is 3:50, 42 mph indicated is 60 actual speed.
Old Aug 1, 2019 | 07:00 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
It depends on the rest of the system. Need to know the trans and speedo info to give you the best approach to bringing it back to correct.
Old Aug 1, 2019 | 07:32 PM
electricmaniac's Avatar
electricmaniac
Truckee is right, really need to know the set up on transmission and tire size.
If everything is to your liking with regards to those, and speedometer is still not right, and you have a mechanical cable speedometer cable, you have some choices.
For some transmissions, different drive gears in the transmission itself can be changed.
Another option is to to look for a speedometer cable ratio adapter (google) that increases the rotation of the cable.
Old Aug 2, 2019 | 08:46 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Rule of thumb is 1 SPEEDO cable gear = + or - 5 MPH
https://www.tciauto.com/speedometer-gear-calculator
Old Aug 3, 2019 | 06:04 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Right, so since you are reading 18 MPH too fast, a driven gear with 3 more teeth than what you have in there now should put you in the ballpark (provided that a gear with that number of teeth exists).
Old Aug 7, 2019 | 10:41 AM
vonhef's Avatar
vonhef
I used the site listed below to order the correct gears for my TH350. Not sure if it will work for your transmission.
thundair
Apr 28, 2015 04:16 PM
coopdagook
Jul 31, 2011 05:33 PM
ol orange
Aug 14, 2010 12:48 PM
HD74
Sep 30, 2009 08:55 AM
NoMo
Jul 20, 2002 07:40 AM
