F1 steering column help
Old Apr 16, 2020 | 03:09 PM
Fin-doctor's Avatar
Fin-doctor
Hi Guys, I’m new to the sight. I just bought a 1950 F1 that’s in pretty good shape but needs a few things. The steering wheel is all loosey goosey. Not driving. Just sitting I can move the wheel back and forth, up and down like there is no bearing in the top of the column. I took the wheel off and the shaft is all loose. It looks like there may be what’s left of a bearing in there but nothing that looks like I expected to see by looking at the parts in the catalog. This all stock by the way. I don’t see any spring or bearing sleeve. To service this do I need to pull the column out? I can hook what looks like what’s left of a bearing but it won’t come out. Any insight would be much appreciated.
John
Old Apr 16, 2020 | 05:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to the forum!
That's quite the situation you have. Is your truck a floor shift or column shift? (a 50 could be either) Either way, I would think you can get by with just pulling the outer tube off the steering shaft with the gearbox intact, IF the tube doesn't hit the roof of the truck before clearing the shaft. I think there's room to do that.
If it's a column shift, you'll need to pull all the shifter parts off the column first.
If it is floor shift, just loosen the clamp at the bottom of the tube, next to the gearbox, and remove the clamp on the bottom of the dash. It would probably help to remove the plates where the tube penetrates the firewall/floor too, but keep track of how they install. Then the tube should just slide off.
I don't see how the upper bearing cup could get down in the tube, so it must be the bearing or spacer that's down there. I kind of doubt any of those parts are available, so check the Parts For Sale thread for a used column, or someone who will sell those parts. Good luck!
Old Apr 16, 2020 | 05:43 PM
3twinridges's Avatar
3twinridges
there is a cup that goes around the steering shaft and rides on the bearing. A spring goes on top of that and is pressed down by the wheel. There is a bearing cup on eBay, I saw it last night.
JB
Old Apr 16, 2020 | 08:08 PM
Fin-doctor's Avatar
Fin-doctor
Thanks for the help. I will pull the column out and see what’s going on.
Old Apr 16, 2020 | 08:37 PM
allout5151's Avatar
allout5151
LMC shows the parts, #9,10,11 https://www.lmctruck.com/1948-56-for...umn-components
okie trucker
Aug 23, 2019 03:46 PM
pezsox
Oct 20, 2017 04:32 PM
ct50f1
Sep 6, 2017 05:55 PM
BM19
19
Jul 26, 2016 07:57 PM
x_man586
Jan 3, 2012 09:02 PM
