1948 Ford F-1 Steering column bearing
Old 10-10-2017, 11:12 AM
pezsox's Avatar
pezsox
pezsox is offline
Well in one of those working to fast moments, I removed the old steering column bearing without measuring where the old one was. Is there a certain distance that this has to be located inside the "column"? thanks
Old 10-13-2017, 02:28 PM
pezsox's Avatar
pezsox
pezsox is offline
I can't believe this one stumped the masters! lol This bearing is located in the "outer" tube/column that goes around the steering shaft. it doesn't look like it makes contact with the shaft at all, does the wheel or ???
Old 10-13-2017, 02:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C = F1:
3517 is the bearing (21A-3517), 3518 is the bearing sleeve (21A-3518), 3520 is the bearing's spring, but it's not listed for 1948.
Old 10-13-2017, 02:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
As I recall, there is something inside the tube that forms a seat for the race. I have column shift, so it's different than yours, but can you feel a lip inside? There has to be something because the race would just fall to the bottom of the tube if there weren't.
The inner part of the bearing fits tight on the shaft, the outer doesn't touch it.
Old 10-13-2017, 03:31 PM
NumberDummy
The bearing and race is a one piece assembly. If the race was a separate part, there would be a basic part number shown for it in these two pics (posts #1 & #3).
Old 10-18-2017, 11:33 PM
pezsox's Avatar
pezsox
pezsox is offline
Bearing question
Can anyone help me with how these are inserted into the steering column "tube" I purchased the plastic piece from lmc but I had an original piece. It all came out at once and I have no clue. Thanks
Old 10-19-2017, 01:48 AM
52 4x4's Avatar
52 4x4
52 4x4 is offline
Since you have the metal sleeve, you don't really need the plastic one. I believe the plastic one is a part number from the 1960's and supercedes the older part. Lube the bearing a bit and install it into the top of the tube. It will stop when it hits a small step in the tube.
Old 10-19-2017, 08:32 AM
pezsox's Avatar
pezsox
pezsox is offline
So drop it down the tube like in pic #1, then follow it with the metal sleeve cone side down?
Old 10-19-2017, 12:01 PM
52 4x4's Avatar
52 4x4
52 4x4 is offline
Yes, just like what's pictured in post #3. - Bob
Old 10-19-2017, 12:12 PM
52 4x4's Avatar
52 4x4
52 4x4 is offline
The 1948-54 Ford Truck Chassis Parts Catalog shows 21A-3520 Spring (Steering Column Upper Bearing) for model years 48-49 (.78" I.D. - 1" long) - Bob
Old 10-19-2017, 12:45 PM
pezsox's Avatar
pezsox
pezsox is offline
so just like this... slide the greased bearing straight down the "tube"
until it catches the notch and then this metal cone down on top and inside of that. all of these of course having been slid over the steering shaft. Thanks. Obviously take more pics next time!!!
Old 10-19-2017, 12:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As I recall, my '52 also has one...
Old 10-20-2017, 04:32 PM
52 4x4's Avatar
52 4x4
52 4x4 is offline
Yes, you probably already have it together by now. Put the spring on just before installing the steering wheel. - Bob
Ross: According to the manual I have, the dimensions for the spring and sleeve were changed slightly for the '50-'52 models.
Bruce Schena
10-13-2017 07:26 AM
ct50f1
09-06-2017 05:55 PM
voodoosurfer
03-27-2011 03:55 PM
brownfoot
32
03-31-2008 09:15 PM
4WD67F250
01-31-2004 02:15 PM
Quick Reply: 1948 Ford F-1 Steering column bearing
