Brake and clutch pedal removal help, 56 f100
Can someone please tell me how to remove the shaft from the pedal assembly on my 56 f100? I have a hanging pedal assembly that I am installing and I can't quite figure out how to remove the shaft that holds the pedals in place. It appears to me that there might be a roll pin on the clutch end that needs to come out in order to slide the shaft out, am I right? Thanks in advance for the help.
Rob
Rob
I'm having issues removing my clutch pedal as well. The above diagram is similar to the one in my shop manual but my locking pin nut is on top.
I guess the question I have, is do I just pound the locking pin out or am I missing something in getting the pedal to release?
If I pound out, do I push it up from the bottom?
You should have seen it before I cleaned it up.
Thanks, That's kind of what I figured. Since I'm new to all this, I'm hoping to avoid too many expensive bonehead moves when I can.
were you able to find a solution to getting this bolt loose?
Greg Rogers
04-24-2022 09:27 AM
zombiefied 247
06-02-2015 10:45 PM
johnson.jeff.a
09-21-2014 09:17 AM
Dano78
09-25-2011 06:28 AM
