2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Smart Junction Box 26 Pin Plug
Old Oct 27, 2025 | 03:01 PM
Leszek68's Avatar
Leszek68
1st Gear
Just hunting down the pin out for the 26 pin C2280D and found this thread. Excellent info because the pinout is here in a PDF which is fantastic info, but the post itself did point to the wrong pin for actually opening the liftgate so thought I would hit this reply for any others looking to actuate the rear hatch. The pin to send the negative signal to is pin 7 as the "Liftgate release switch signal". Pin 16 is not the one to send a signal to in order to operate the liftgate. Pin 16 as noted on the very much appreciated pdf is "Liftgate ajar switch signal". This is the signal that displays output signal from the liftgate latch switch to the BCM. It tells the vehicle computer the current state of the liftgate: open or closed ("ajar" or "not ajar"). This is used to illuminate the dash warning light and control interior lights.
2012 F250 6.2
Nov 21, 2016 08:36 AM
DCRB
Aerostar
19
Jan 15, 2008 06:03 PM
Matt M, PA
Jan 26, 2005 12:51 PM
