View Poll Results: Radiator Repalcement Information - ONLY for ORIGINAL Radiator
Replaced because of failure.
38.46%
Replaced BEFORE failure.
7.69%
Replaced at <100,000 miles
7.69%
Replaced between 100,000 and 150,000 miles
0%
Replaced between 150,000 and 200,000 miles
0%
Replaced between 250,000 and 300,000 miles
23.08%
Replaced between 300,000 and 350,000 miles
7.69%
I had over 350,000 miles on my original unit when I replaced it
7.69%
Replaced with OEM style unit - plastic heads
53.85%
Replaced with 100% aluminum unit
23.08%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
POLL: Radiator Replacement
Old Apr 16, 2020 | 06:35 AM
F250_'s Avatar
F250_
I'm considering a proactive/preemptive replacement for my radiator, and want to hear about all your replacement efforts.
NOTE: This poll only applies to when you replaced your ORIGINAL OEM radiator. If you've had multiple replacements, discuss those details within the thread (brands used, types used, useful life of the those which have not worked well for you, etc).
I am going to assume that the replacement was either because of end-of-life leaks or a preemptive "do it BEFORE it fails" type of event. If you replaced the radiator due to damage from a collision or vandalism, please do not respond to the poll.
- approximate mileage
- how many replacements in a single vehicle
- replaced with OEM style unit with plastic heads (vs all aluminum)
ALSO... if you have NEVER replaced your ORIGINAL OEM radiator, please state that with your current mileage... I neglected to leave a slot for that answer within the poll.
I have 318K miles on my original radiator, and that is sort of why I'm considering replacing it preemptively.
Thanks ahead of time for all your input!
Old Apr 16, 2020 | 07:43 AM
FordTruckNoob's Avatar
FordTruckNoob
I have 362,727 miles on the original radiator I bought the truck with.
Old Apr 16, 2020 | 11:25 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
255,000 miles on OEM radiator. No plans to replace it unless it has a problem, then I will get a 100% aluminum.
It was good to see a poll on here today, it has been a while since the last one...
Old Apr 16, 2020 | 01:10 PM
Dan V's Avatar
Dan V
336k on mine
Old Apr 16, 2020 | 04:16 PM
duck fan's Avatar
duck fan
Because racetruck
The option of 250-300K is missing. That's when mine was replaced
Old Apr 16, 2020 | 04:23 PM
FordTruckNoob
Huh? It's the 6th selection from the top.
Old Apr 16, 2020 | 04:52 PM
F250_'s Avatar
F250_
Yep, like FordTruckNoob said, it's there in the list. The one I missed is 200-250K.
Old Apr 16, 2020 | 07:33 PM
M3rc's Avatar
M3rc
FWIW, I believe it was pirate that cut apart an Autozone duralast replacement and said it was identical to the OEM one(and a lot cheaper and warrantied at any Autozone).
Old Apr 16, 2020 | 10:20 PM
cjfarm11's Avatar
cjfarm11
I had a failure on my 6.0 at 170,000. My 7.3 is still
going but it only has 130,000 on it.
Old Apr 18, 2020 | 08:52 AM
TheFecalFanatic's Avatar
TheFecalFanatic
Anyone have experience with the Mishimoto Aluminum rads? I ordered a stock style for my truck and it came busted. Looking into the Mishimoto now, it's for an OBS, but what is the general consensus on Mishimoto radiators?
Who's had them, warranty, quality, etc.
-Jake
Old Apr 18, 2020 | 12:19 PM
Bill De's Avatar
Bill De
180,000 on the original rad, no plans to change unless something happens. I'm the original owner.
Old Apr 18, 2020 | 01:12 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Replaced after failure at 325,000 with a NAPA unit! Have nearly 150,000 on it so far!
Old Apr 18, 2020 | 06:47 PM
SkySkiJason's Avatar
SkySkiJason
I’ve installed a bunch of Spectra brand (autozone, etc) radiators and have not seen a failure yet.
The all aluminum units are a good upgrade for the failure prone 6.0 radiators. Waste of $$$ on a 7.3.
Catastrophic failure is rare and unlikely. This is about one of the easiest radiators on earth to swap. Under and hour in labor? Not something I would do as PM...
Old Apr 18, 2020 | 07:06 PM
Bently_Coop's Avatar
Bently_Coop
Replaced my OEM for a OEM with the OTW transmission cooler since my 99 F250 V10 didn't come with.
One of the better upgrades/OEM modifications for my truck.
Old Apr 20, 2020 | 04:38 AM
JOHN2001's Avatar
JOHN2001
I was kinda disappointed there was no, "I have no idea I just like to vote" option in your list.
