Power windows , passenger side
Old Apr 15, 2020 | 08:22 PM
greg3131's Avatar
greg3131
My truck sat for a couple years . Truck runs great . However, the passenger side window and rear passenger side window do not work . I checked the fuses , all good .
Any suggestions or ideas ? Thank You
Old Apr 16, 2020 | 06:53 AM
Listor's Avatar
Listor
have you verified that you have power over there, just because the fuse is good doesn't mean much
Old Apr 16, 2020 | 08:48 AM
bigb56's Avatar
bigb56
The problem could be at the drivers door as well, everything passes through the master switches. If I recall there is always power at each motor and the switch just completes the ground. Also check the wires in the door jamb inside the rubber accordion on the drivers door.
Old Apr 16, 2020 | 01:44 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Attached are some wiring diagrams that may be of help to you. There are different ones for a crew cab truck...
Old Apr 16, 2020 | 04:55 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Depending on where it sat for years it maybe as simple as there stuck. Have someone work the switch while you manually assist the window. I would try the simple first before making it into something bigger.
Old Apr 16, 2020 | 09:19 PM
greg3131's Avatar
greg3131
thanks for the help , I tested the main switch on the driver's side- it is good . I tested the passenger switch - no power .
I suspect there must be a broke wire somewhere. Finding that broke wire ? Very little room to work ?
Kendal
May 10, 2016 12:50 PM
djfordman81005
1997 - 2003 F150
Jan 17, 2011 09:09 AM
zekelander
1997 - 2003 F150
Sep 20, 2004 08:20 PM
Peacedog
Aerostar
Sep 6, 2004 10:43 PM
