Sponsored by: Real Truck
In bed 7 pin install
Old Apr 14, 2020 | 10:21 PM
Oredigger's Avatar
Oredigger
2016 F-350
i had bookmarked a thread with the hole template for BC3Z-13A576-A part install but computer recently died. Can’t for the life of me find that thread again. Looking for the pdf that you can print to line up the factory location and weird looking hole that needs to get cut. Any help would be appreciated. Thanks
Old Apr 16, 2020 | 08:44 PM
Oredigger's Avatar
Oredigger
This is what I’m talking about
Old Apr 17, 2020 | 10:08 AM
Super Duty DJ's Avatar
Super Duty DJ
I had mine installed post-factory by the dealership. I'll see if I can get you some measurements later today with some pictures. The way they did mine is by using probably a 2-2.5" hole saw for the center section, then they just used self-drilling sheet metal screws to hold the bracket to the bed-side rather than the clip-nuts like you are showing.
Edit: I've also got the instructions that they used for installing the puck cross-piece under the bed, so I will see if there is a page in there with a template for installing the in-bed electrical piece.
Old Apr 17, 2020 | 10:23 AM
Oredigger's Avatar
Oredigger
Great, thanks!
Old Apr 19, 2020 | 01:09 PM
Super Duty DJ
Sorry it took me a couple days to get these pictures. The documentation for the under-bed pucks piece doesn't have any information on the location for the electrical piece. As you can see in the attached pictures, it's about 5 3/4" forward from the back post to the mounting holes and about 2" up from the bottom of the board pocket. I think you could easily move it up another inch or more to leave the board pocket/shelf completely open for a 2x6 or 2x8 to still be able to go there.
Old Apr 19, 2020 | 07:25 PM
Oredigger's Avatar
Oredigger
Awesome, thank you
Old Apr 20, 2020 | 01:50 PM
Super Duty DJ
You are welcome.
Old Apr 22, 2020 | 10:48 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Hole saw needed is 2 1/8"
Tonto Kowalski
46
Feb 21, 2022 07:02 AM
PghFamilyMan
Aug 6, 2019 03:43 PM
grantrekker
All Things Towing
13
Jan 21, 2019 08:22 AM
shortride
Jun 8, 2017 08:01 AM
49m47
Apr 3, 2011 02:23 PM
