Sponsored by: Real Truck
Won't start
Old Apr 14, 2020 | 03:01 PM
Catfishious's Avatar
Catfishious
4wd Low
Won't start
2002 F350 Super Duty 5.4
My truck just died going down the road yesterday and won't start again. It had been doing this off and on but always started back up. Any suggestions?
Old Apr 14, 2020 | 05:01 PM
seville009's Avatar
seville009
Since it died while running, first suspect would be in the fuel/fuel delivery system.
could also be that the alternator isn’t working and the battery died, but presumably you would have had a light on your dash pop up. Check the battery voltage.
check for codes first though in case it’s something simple
Old Apr 14, 2020 | 06:55 PM
Djosbun's Avatar
Djosbun
It could be 20 different things. It's not possible to give any help that's not solely a guess with such minimal information, unless you just want guesses to work off of.
I'll start: broken wire in the harness that powers the fuel pump control module due to rodent chewing or large road debris. Vibration causes connection issue at the wire damage point.
Next.
-- Dave
Old Apr 15, 2020 | 12:53 PM
Catfishious
4wd Low
More
Thanks for the tips, but it's not the battery or fuel pump. Truck still turns over but she sounds as if there isn't fire going to the plugs. I had issues of this nature before and changed the CPS. IT seemed to fix it, but about two weeks later it gradually started again. Now all she does is turn over.
Old Apr 15, 2020 | 06:34 PM
99f350sd's Avatar
99f350sd
Listen for the fuel pump for 2 secs with key on..
Old Apr 17, 2020 | 03:04 AM
Catfishious
4wd Low
Big thanks
Next.
-- Dave
Ok, so it wasn't a wire problem, but it was the fuel system. Fuel relay to be exact. Something is still not quite right, but at least I can get to work,and to the service calls. Thanks for the help. Because my scan tool won't give a reading if the truck isn't running. Changed out the fuse panel, which includes the fuel relay built in. It's beyond me why they would do that, but I'm not a car and truck designer.
Blake Savage
Jun 2, 2017 02:11 PM
mark227
Dec 16, 2016 12:17 PM
FD-213
Jul 12, 2011 09:16 AM
Killian88
1997 - 2003 F150
Jan 15, 2011 07:23 AM
dpm1057
Apr 25, 2007 01:38 PM
