Y Block Rocker Arm threads
Old Apr 13, 2020 | 03:27 PM
SeaCarr's Avatar
SeaCarr
I'm a little confused on the thread size for 292 rocker arms. I took out the adjusting screws to clean. Several are really tight. Others feel normal. I'm wondering if i should try to chase the threads? What size tap? Then I read something about "interference threads" in the rocker arms. The 7/16X20 tap will wipe those out and the adjusting screws will be loose. I think the screws that are really tight will hinder adjustment. The threads on the screws are nice.
Old Apr 13, 2020 | 03:40 PM
Tedster9's Avatar
Tedster9
I wouldn't chase the threads. They need to be tight, and stay put. There is a minimum torque spec for the screws in the book below which they should be replaced. I bought NOS rocker arms w/screws when rebuilding the heads in my Y block, and I can testify it is important to have ate yer Wheaties that morning before adjusting the valve lash. Use a breaker bar or extension for leverage.
Old Apr 13, 2020 | 04:13 PM
KULTULZ's Avatar
KULTULZ
Question
Where is this thread you are describing?
Old Apr 13, 2020 | 05:08 PM
matthewq4b's Avatar
matthewq4b
Ya the thread is a wave thread to keep them put once adjusted.
Old Apr 13, 2020 | 05:45 PM
SeaCarr's Avatar
SeaCarr
Thanks. I'll leave them tight!
expolice
Feb 21, 2013 08:00 PM
460user
2004 - 2008 F150
Sep 3, 2010 08:40 AM
PROSTOCK
Jul 8, 2008 05:52 AM
xfordman
Sep 16, 2005 03:50 PM
inliner
Aug 17, 2003 12:36 PM
