No headlights
Old Apr 12, 2020 | 11:53 PM
Dean06919's Avatar
Dean06919
No headlights
1994 F350, 5.8. Truck has the FSB headlight relays as it burned out the last headlamp switch, which seems to be common on these trucks. I replaced the headlamp switch at that time with a Dorman unit.
Headlights stopped working tonight. No bright or dim. All other lights work, including tail lights. Luckily, when pulling back on the multifunction switch, the brights would come on, so I drove home with the switch pulled back.
Too late to dig into it tonight. Any suggestions? I don't think it would be a fuse or relay since the brights do come on when pulling back on the multi function switch. Headlamp switch or MF switch?
Old Apr 13, 2020 | 01:39 AM
raystankewitz's Avatar
raystankewitz
You know, I think I would look at the multi-function switch, as long as I knew the plug for the headlight switch was not cooked when I changed the switch out. It sounds like the multi-function switch decided it was done working. I guess you could meter it to see if it's bad if you had the schematic for the steering column.
Old Apr 13, 2020 | 03:42 PM
torq'ta 5 8's Avatar
torq'ta 5 8
maybe this could help
Part 1 -How to Test the Ford Headlight Switch
Old Apr 19, 2020 | 07:45 PM
Dean06919's Avatar
Dean06919
Finally got a chance to use the link provided by torq'ta 5 8. I jumped B1 and H and did not have headlights. After metering B1, I found out B1 has 0.5 Volts instead of 12V. The headlight switched passed a continuity test. I also checked all the fuses, all had continuity, I did not see a headlight relay.
I haven't found a site that explains how to test the multi-function switch, yet. Do you think it probable that the MF could be bad and only allowing 0.5 volts to wire B1?
Old Jul 19, 2020 | 06:17 PM
Dean06919's Avatar
Dean06919
BTT, I would really appreciate any help.I have 12 volts to the fuse in the power distribution box. Also, the headlights come on when pulling back (flash mode) on the multifunction switch.
I switched out the multifunction switch and headlight switch, still no headlights. Not sure what to do. Jumping B1 and H resulted in no headlights with B1 having 0.5V instead of 12V. I used the following test as provided by Torqta'5.8.
https://troubleshootmyvehicle.com/fo...light-switch-1
Old Jul 20, 2020 | 09:41 AM
rla2005's Avatar
rla2005
If there is no power on the Black/Orange wire (B1) you have an open fuse (Fuse R 40A) or an open circuit between the engine compartment fuse box and the headlamp switch.
Four.on.the.floor
Feb 17, 2017 09:32 AM
ErrorS
1978 - 1996 Big Bronco
18
Feb 17, 2013 03:15 AM
Hank85713
1983 - 2012 Ranger & B-Series
May 7, 2009 10:22 PM
newkyford
Dec 15, 2006 11:45 AM
g-a-w-d
Aug 27, 2003 07:14 AM
