Adding a camper shell-Questions
Old Apr 12, 2020 | 06:06 PM
Fillibuster's Avatar
Fillibuster
Trailering
I bought a camper shell from a salvage yard for my 2006 screw, but I can’t go get it yet, because, you know…
I’d like to ask help from people with a camper shell or know how to install one:
1. What clamps/brackets do you have or recommend to hold it on? They said they don’t have them, so I need to buy ‘em.
2. I have a bed liner, it has the plastic pieces on the top of the sides of the bed. However, the front of my bed doesn’t have any plastic piece on top.
I watched a video that said I should use weatherstripping on the front.
I found this at Home Depot. Is this the right stuff: Camper Seal Foam Tape?
https://www.homedepot.com/p/M-D-Buil...2352/202066511
- Question: Is it helpful to put weatherstripping on the top of the sides, too? Or just the top of the front of the bed?
Any other thoughts on adding a camper shell?
Isn’t it funny how “Camper shell” has different names in different areas?
Here are pictures of the camper shell and of my bed, where there is no liner on the front.
Thank you!
Camper shell from salvage yard
Old Apr 15, 2020 | 10:13 PM
steve(ill)'s Avatar
steve(ill)
If it is permanent, many will drill 2-3 holes on each side and bolt to the top face.... If you have it on and off often, i have seen people use 4 small C-clamps... maybe 3 inch size to hold the shell in place... Look at the shell first, it may have foam on the bottom face, it may not... A lot depends on how often you remove and if you want it WATER TIGHT .
Old Apr 16, 2020 | 02:33 PM
tlrtucker's Avatar
tlrtucker
There's a thing called camper shell clamps. Easy google search there buddy.
Old Apr 16, 2020 | 09:55 PM
Lime1GT's Avatar
Lime1GT
Lots to choose from here. Sealing tape and clamp varieties to choose from. https://www.truckoutfittersplus.com/
Old Apr 17, 2020 | 06:41 AM
cmorningstar01's Avatar
cmorningstar01
You can remove the plastic plugs in the top of the bed rail caps and use J bolts to hold the shell down, As for a seal along the front edge there are a number of options from self sticking foam to rubber/vinyl weather stripping fastened to the underside of the camper cap shell...Are you sure there is not already some type of weather strip/seal fastened to the underside of the camper shell, If this fits your vehicle then most likely the vehicle it came from had a weather tight seal and it would be logical it was on the underside of the front edge of the cap.
Just a thought...check to see what is currently on the cap
Valerie
Old Apr 26, 2020 | 12:35 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree, it will be revealing to see what's holding the cap on the donor truck.
98ramtough
31
Apr 22, 2026 07:27 PM
ZonaNavyStar
Aug 1, 2008 10:01 PM
madcow
Aug 21, 2001 10:12 AM
