67 Econoline won’t shift
Old Apr 17, 2020 | 10:49 AM
  #31
Adam Jurek's Avatar
Adam Jurek
Originally Posted by EmilBarnabas
Grind with the clutch pedal pressed to the floor?
more like a grinding when I try to shift.
Old Apr 17, 2020 | 04:50 PM
  #32
Adam Jurek's Avatar
Adam Jurek
Originally Posted by tjc transport
than your clutch is not working.
so replace the clutch?
Old Apr 17, 2020 | 05:35 PM
  #33
tjc transport's Avatar
tjc transport
i ain't rite
no.you need to troubleshoot it. is the pedal going down when stepped on? is it moving the arm going into the bellhousing?
is the linkage hooked up? is it properly adjusted?
replacing the clutch will not do any good if parts are missing or not working properly.
Old Apr 17, 2020 | 06:47 PM
  #34
Adam Jurek's Avatar
Adam Jurek
yes yes yes yes
Old Apr 25, 2020 | 07:03 AM
  #35
tjc transport
i ain't rite
so did you ever figure out what was wrong?
Old May 6, 2020 | 06:23 PM
  #36
bmuhlbach's Avatar
bmuhlbach
this is what the shift tube looks like
brand new nos. shift forks. Green sales in cinn. Ohio has more
Old May 13, 2020 | 03:57 PM
  #37
stm76's Avatar
stm76
Originally Posted by Adam Jurek
No these old ford vans don’t move up and down
Just wanted to jump in here and say that the shifter most definitely DOES move up and down in addition to forward and backward. You lift up toward the ceiling and pull toward you to get into first gear. lift up toward the ceiling and push toward the windshield to get into reverse. Down toward the floor and forward toward the windshield is second gear, then pull it straight back from second toward you to get into third gear. If the shifter didn't move up and down, you couldn't differentiate between first/reverse and second/third. Have you driven a manual "three on the tree" before? I drive mine just about every day. Now if you have an automatic, you would be correct, the shifter would have no need to move up and down.
Old Jun 21, 2021 | 04:04 PM
  #38
Adam Jurek's Avatar
Adam Jurek
Do you happen to know how to time these things, just bought a new distributor and tried watching some videos but seems very complicated
Old Jun 25, 2021 | 11:49 PM
  #39
85e150's Avatar
85e150
You have to find TDC on the number 1 cylinder on the compression stroke. Then find the number 1 plug fitting on the distributor. Make sure the rotor is pointed at that fitting. When you put the distributor in, it will turn the rotor a little due to the cut of the gears. Compensate for that when you put the distributor in.
Do you have a timing light?
Can you see the front of the crankshaft? Look for a pointer and some kind of mark. The mark should be near the pointer when the distributor is pointing at cylinder number one. Once you are close, you get it started and slowly move the distributor until the mark is at the pointer.
Of course, you have to find the factory ****, which is probably 6 or 8 degress BTDC, and make sure the mark is at that point also.
If you don't have a timing light or there are no marks, no pointer--it will be pretty tough to get the right timing. You'll have to get things lined up the best you can, and adjust it slowly at idle. Go for the best idle, then back it off a little.
Run it, see how it works.
Got your clutch, brake & shifter all sorted out?
Chuckwagon101
Jul 22, 2017 07:57 PM
rexblue
Apr 19, 2015 08:29 AM
Duncansm
Jun 6, 2014 06:00 PM
