67 Econoline won’t shift
Old Apr 14, 2020 | 06:02 PM
EmilBarnabas's Avatar
EmilBarnabas
When you disconnected the long shift rods, were you able to move the levers on the side of the transmission? Each one should have three positions. One must be in the center position (neutral) in order for the other lever to move.
Old Apr 15, 2020 | 03:06 AM
Adam Jurek's Avatar
Adam Jurek
yes I have and I connected all back up and still didn’t shift
Old Apr 15, 2020 | 03:08 AM
Adam Jurek's Avatar
Adam Jurek
Brake fluid
Another problem is I can’t find where to put the brake fluid. There is no place anywhere on the van to put fluid into other than oils cap.
Old Apr 15, 2020 | 06:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
with the rods disconnected from the bottom of the steering column, can you move the shifter in the cab?
first gear pull shifter toward you and then push down. second is lift shifter up out of first, and push toward dash, then push up. then third straight down. reverse is pull to you and push up.
Old Apr 15, 2020 | 07:30 AM
Tedster9's Avatar
Tedster9
Adam - do yourself a solid and pickup a reprint copy of the Operator's Manual. Even better, the Ford Shop Manual. All that stuff is in thar. And then some. Fluid types and quantities, voltages, torque specs, troubleshooting and repair etc etc.
Old Apr 15, 2020 | 08:10 AM
tjc transport
i ain't rite
if i remember correctly, the brake master cylinder is under the van, towards the front connected to the brake pedal where it comes through the floor.
Old Apr 15, 2020 | 02:13 PM
Adam Jurek's Avatar
Adam Jurek
I just bought one off of amazons last night, thank you everyone who has helped me
Old Apr 15, 2020 | 04:43 PM
Adam Jurek's Avatar
Adam Jurek
the shift *** does not move up and down
Old Apr 16, 2020 | 12:00 PM
tjc transport
i ain't rite
than something is locked up in the column.
Old Apr 16, 2020 | 02:52 PM
Adam Jurek's Avatar
Adam Jurek
No these old ford vans don’t move up and down
Old Apr 16, 2020 | 03:18 PM
tjc transport
i ain't rite
the shifter works like a "H". to you and UP is reverse. to you and DOWN is first. away from you and UP is second. away from you and DOWN is third.the shifter works in 4 different quadrants. if it does not move in a "H" pattern, something is locked up in the column.
Old Apr 16, 2020 | 04:41 PM
Adam Jurek's Avatar
Adam Jurek
Ok I got all of that but when I turn it on and try to shift into any gear all that happens is it grinds and won’t go into gear
Old Apr 16, 2020 | 06:48 PM
  #28
EmilBarnabas
Grind with the clutch pedal pressed to the floor?
Old Apr 16, 2020 | 06:50 PM
  #29
EmilBarnabas
The brake reservoir is in the floor, just in front of the driver's seat.
Old Apr 17, 2020 | 07:07 AM
  #30
tjc transport
i ain't rite
than your clutch is not working.
