DIY Truck Bed Slider
As an isolation project, I decided to make a truck bed slider. I copied the design cwood used, with a few tweaks of my own.
It's not perfect, there's a few little issues. I used 2 x 4 lumber for the drawer sides and the base sides and they're slightly warped. I thought attaching the steel rails to them would straighten them out, but the rails conformed to the 2x4 instead! It still works however, there's a little binding but for the most part it moves quite smoothly.
I used a 1/2" bolt as a pin for locking the drawer in place. I drilled a hole through the bolt and used aircraft wire to secure the bolt so I don't lose it!
In the future I'd probably spend the extra money for straighter lumber, but for now this solution works. I plan to add dividers for groceries and other items to section things out a bit. I'm also going to paint it, not sure what color yet.
It's a good weekend project and it will make life way easier going forward!
I know there’s some type that can be applied like paint with a roller and the results are awesome.
I’ve seen it applied to a wood sub woofer cabinet.
I'm actually not sure about the weight, right now the base is just sitting in the back of the bed. I haven't locked the base into position, once I do that I'll have to test it out. Not sure if it would handle 800 lbs, that might be pushing it.
1320stang
15
07-17-2018 08:39 AM
Grandevoodoo
06-05-2018 11:01 PM
