DIY bed slide
Old Mar 28, 2015 | 08:04 AM
cwood's Avatar
cwood
DIY bed slide
I recently switched vehicles to a 2012 Fx4 Screw.
I do a lot of kiteboarding and other outdoor stuff and with a hard tonneau this is the perfect vehicle....except having to dive for stuff at the back of the bed.
I spent a ton of time looking at options for a slide. Commercial are way expensive and overkill so I decided to make my own. I also wanted it quickly removable for heavy or dirty loads.
Giant drawer slides are very expensive and I found some ideas on line for using skateboard bearings and square tube as slides.
Worked out really well. Coated it all in Behr Overdeck textured...which is like bed liner but 1/3 the price.
Note the extended picture it is resting a bit on the tailgate because I have not added ballast at the front of the base. Used a 50 lb 1/2" steel plate.
Base ply notched for full length and to ensure captive between closed tailgate and front wall.
Set up to drill accurately spaced holes
Testing spacing
Close up of bearing
Bearings
Rails and runners mocked up
Testing fully assembled
Extended
Painted and with retention pin to stop from over extending. Slider is locked in place on its own when tailgate is closed.
Painted and extended
Old Mar 28, 2015 | 09:28 AM
Buck268's Avatar
Buck268
Well done! How long did that all take? Estimated DIY cost?
Old Mar 28, 2015 | 09:37 AM
cwood's Avatar
cwood
Thanks!
Not that long once I had the materials. Afternoon to build, few hours to paint.
Estimated costs:
3/4" and 1/2" 4x8 sheets $75
Poplar rails $50
Bearings $30
Square tube $25
Nuts and bolts etc $20
Paint: $50
Guessing just over $200
Old Mar 28, 2015 | 02:48 PM
PinMd's Avatar
PinMd
Very nice! I really like your idea for the rollers/track. I did one myself, went a different route with it. Its not installed right now, built it for my 2005, just traded it in on a 2014. Waiting to get my cap installed before putting it in this one. Will post some photos.
Old Mar 28, 2015 | 03:10 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Very nice build and write up! I'm a little jealous as I'm still using a four prong garden hoe to pull my stuff forward.
Old Mar 31, 2015 | 10:40 AM
blueovelboy's Avatar
blueovelboy
I use the back up hit the brakes till it slides to the reachable spot method
Old Apr 1, 2015 | 11:18 PM
RRRSkinner's Avatar
RRRSkinner
I read several different bed slides and decided to design my own. The bottom 1/2 osb, side rails 2x8. I used 5/8 roller bearings from harbor freight 15 of them. On the drawer I used 3/4 ply and build the sides with 1x4. I decided to use a 2x2 angle iron 1/8" for the bearings to roll on and a 2x2 1/8 flat for the center rollers
Anyhow the outer box is attached to a full sheet of ply, so the inside is 45" when you subtract the space for the 2x (3"), so I built the drawer 94 1/2" x 44 1/4 to leave space for the angle metal. I glued and screwed everything.
Right now I am letting the drawer tip on the tail gate and it is working great, but I could put regular bearings above the drawer to hold it. If I do that, I will probably put some 3/4" angle metal on top the drawer so that it is metal to metal instead of metal to wood.
Let me know if this isn't clear or you want some pics...I painted it with black semi-gloss.
Old Oct 13, 2017 | 05:42 PM
Wanderingbob's Avatar
Wanderingbob
Very nice. What did you use for retention pin?
Old Apr 30, 2020 | 09:47 PM
Dylan Cole's Avatar
Dylan Cole
how did you attach the 2x2 angle iron to the 1x4?
Jmh2
Jul 6, 2019 05:57 PM
mrpotatohead
May 8, 2017 08:58 AM
"Top Fuel" Bender
Ford Truck Parts for Sale
Sep 14, 2012 06:30 PM
JB666Rock
Mar 29, 2008 10:00 PM
F-3504x4Mamma
Jul 18, 2006 11:45 PM
