Yeah... it's not doing that.. It's actually hard to get it over 900. Idles about 200 to 300, and vairies from there up to about 800 depending on what I'm doing. I have not towed anything yet to see how that affects the EGT. I'm wondering what will happen when towing like 5000 lbs or more up and down hills. Or, driving over the sand like I do a lot when surf fishing in Cape Hatteras.
Thanks.
Just keep an eye on EGTs when towing with your foot deep into the pedal. EGTs can hit 1300 briefly, for me 20 seconds is the end of my bravery. The gasses are 1300* but the metal bits take time to soak up the heat. Sustained EGTs of 1300 or more will eventually heat soak the important reciprocating metal bits and they'll melt.
If you suddenly notice the EGTs are too high and you don't know for how long, slow down and keep rolling down the road with the engine running to maximize cooling.
I’ve read in the past that some people tap both driver and passenger manifolds for a more complete picture of temps. Is that still common thought? Is there a good dual gauge available? The PO of my truck installed the temp probe just after the turbo before the the down turn in the exhaust pipe. I will be putting in the correct location on my next project.
Thanks Jason. Is driver side the usual location just because of proximity to gauge cluster?
Also, slow on “thanks” for your help with my H&H mod. Worked out perfectly.
Good advice from all. The gauge install kit should come with directions and drill bit/tap size. Get one of these from Harbor Freight and make the job 100 times easier and less prone to screwing it up.
Yes and no downpipe in the way.
Is it your tubing I just got back in the mail yesterday??? You shoulda told me it didn’t show up!!
The (regular) envelope was damaged at the mailing address and was unable to be delivered or something.... I guess I’ve just been lucky with the others I sent like that. I’ll invest in bubble wrap envelopes from now on.
Figured you got busy in the shop. Not a biggy. I appreciate all the excellent input. Hope there is enough wire to get me to the new location for reinstalling. Just fill old hole with 1/8” NPT plug right?
