Hard to start issue
Old Apr 8, 2020 | 07:44 AM
Punisher29073's Avatar
Punisher29073
Hard to start issue
My truck started to get harder and harder to start after sitting for a few days. When it would finally start, it would puff white smoke. I check the GPR and replaced the glow plugs and uvch with motorcraft parts. That did not fix it.
This problem got progressively worse. It has 235k mi on it. My thought was that injectors were headed south. So to verify, i took it to a local shop to have them diagnose. They said that the starter was bad and the pcm was interfering with the charging system. I bought a starter and took it to them for install.
The new starter spun much faster so I accept the old one was going bad. The pcm problem baffled me a little. After putting the starter on the mechanic said it did look like the injectors were going bad too. He wanted $800-$1300 to replace them if i brought him the injectors so i decided to do them myself.
I ordered Swamps stage 1 and got them installed. Installation went fine. Everything happened as instructions said it would. Drove the truck for a few days and it felt like it was taking longer than it should to start but I attributed it to air in the lines.
The truck sat for 2 days and I went to start this morning, 60 degrees, and it would not start. Killed the batteries trying to start it for a few minutes. I plugged in a cheap OBD scanner and it wont even come on. This has got my mind going back to the PCM but all the dash and gauges are acting as they should when you try start it.
Any guidance would be appreciated.
ryan
Old Apr 8, 2020 | 09:20 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
how did you check the GPR? when you killed the batts this last time cranking were you getting white smoke out the tail?
Old Apr 8, 2020 | 10:39 AM
Punisher29073
i have checked the GPR. Good there.
no more white smoke from tailpipe since I replaced injectors.
ryan
Old Apr 8, 2020 | 10:40 AM
Punisher29073
This is from this morning. There is an odd sound coming from dash to right of instrument cluster that wasnt there before.
is there a video attached?
ryan
cbutcher
25
Oct 28, 2019 12:41 AM
Groundpounder0331
Jun 22, 2013 02:04 PM
k2vailkid
13
Jun 16, 2009 02:01 PM
CheaperJeeper
Nov 10, 2008 10:41 AM
Capt.Schenk
Oct 27, 2007 12:28 PM
