Help identify these plugs
Old Apr 7, 2020 | 04:41 PM
Mikulh's Avatar
Mikulh
Hello,
I'm in the process of swapping from a 4.9L to 5.8L in my '91 F150.
I was able to scavenge a '91 F150 engine wiring harness from a junkyard.
I have a question about two of the plugs.
1. This plug appears to go to the AIR tubes on the back of the engine which I am not running since I am using GT40 heads.
If I leave this unplugged will it cause a CEL? If so, is there a way to fool the computer?
2. This plug comes out near the 4 main plugs that connect the engine wiring harness to the chassis wiring. I have no idea what this one goes to. Can anyone help me out? Could someone possibly snap a picture of where this plug hooks up on your truck?
Old Apr 7, 2020 | 04:49 PM
1TonBasecamp's Avatar
1TonBasecamp
I'll see what I can come up with in the way of pics, but while you've got such good access to them post up the wire colors too.
I'm sure there are members here that can look at a plug and see the orientation and know right away what it's for, but the wire colors can still confirm things.
Paul
Old Apr 8, 2020 | 02:32 PM
Mikulh's Avatar
Mikulh
Ok. It appears the wires going to the plug at the rear of the engine are Yellow/Red Stripe and White/Red Stripe.
And the wires going to the plug that is near the 4 main engine wiring harness plugs are Yellow/Green Stripe and White/Red Stripe
Old Apr 8, 2020 | 02:50 PM
1TonBasecamp
Perfect! That should help someone get you the answer I'm sure.
I'll look in my '93 diagrams even though yours is a '91 because there's still a good chance that the colors remained the same for whatever their function was.
Paul
Old Apr 8, 2020 | 03:02 PM
My4Fordtrucks's Avatar
My4Fordtrucks
1) 5.0L knock sensor
2) Looks like a fuel injector connector. With those long wires maybe A/C compressor? If the harness is were it is supposed to go...what has a plug like that that it will reach?
Old Apr 8, 2020 | 03:13 PM
Mikulh's Avatar
Mikulh
So, if 1 is for the knock sensor, I should be able to leave it disconnected for my 5.8L, correct?
I agree, 2 does look like a fuel injector connect, but it's not... All of the injectors are already plugged in and it's in the wrong place on the harness for an injector... hence my confusion.
Old Apr 8, 2020 | 03:47 PM
Mikulh's Avatar
Mikulh
A/C and injectors are already hooked up. I've looked in the truck for something in that area with a plug that looks like that... still haven't found anything. That's why I was hoping someone could snap a picture for me.
Old Apr 8, 2020 | 07:49 PM
My4Fordtrucks
Power steering pressure switch?
Old Apr 9, 2020 | 10:24 AM
Mikulh's Avatar
Mikulh
You may be onto something with that. My truck doesn't have a switch on the power steering line, but I think some do.
I bought this wiring harness from an online junkyard, so I don't know if the donor truck did or not.
Can someone please check their truck to see if they have this connector, and what it's plugged into?
If you can't snap a pic that's ok. I just need some verification about where it goes.
Also, if you find that your truck doesn't have that plug, that could be useful info too... Maybe I don't need it and can just zip tie it out of sight.
Old Apr 9, 2020 | 05:15 PM
1TonBasecamp
Looked at mine yesterday and did not see anything on the P/S pump. F150, '93 w/5.8 and E4OD.
Paul
Old Apr 9, 2020 | 06:01 PM
My4Fordtrucks
Paul
The sensor is on the pressure hose. Not the pump. 351 equipped trucks did not have them.
Old Apr 9, 2020 | 06:40 PM
ifrythings's Avatar
ifrythings
First plug is for the knock sensor (5.0L only)
second plug is the power steering pressure switch (5.0L only)
also the wire your calling white/red is actually grey/red, they can be hard to see at times.
Old Apr 9, 2020 | 07:05 PM
Mikulh's Avatar
Mikulh
Thank you so much! That is exactly what I needed to know.
Since this is going on a 5.8L I shouldn't need either one. I'll just zip-tie them neatly out of the way.
Thanks again!
RacinNdrummin
May 31, 2017 08:59 PM
Toddster
Mar 26, 2017 09:41 AM
njsvtguy
Jun 22, 2014 11:30 AM
DasCheckers
Mar 12, 2011 05:00 AM
Dutch123
1978 - 1996 Big Bronco
Jul 19, 2003 01:08 AM
