5.4 l 2004 timing gone wrong
Old Apr 6, 2020 | 12:46 PM
Gabbo81's Avatar
Gabbo81
So wondering if i can get a little help, i redid the complete timing job/phasers on my vehicle didnt use the crank locking tool but did set the crank sproket dot at the six oclock position leaving the key mark at the eleven o clock position, went old school like utube said and marked the cams and locked in place with trusty vise grips before removing chains and phasers....so i know for a fact nothing moved,,,, long story short , pretty dang sure i put it back out of timming becuase she sounds smooth but has no power and idles really rough,,, i am wondering how to completely set the timing back in place i know the correct process of removing the rollar arms and all that but after i remove all the rollers and have the cams nuetral, do i just like spin the cams to get the markings or what, im lost on that part.
Old Apr 6, 2020 | 01:27 PM
Kramercd's Avatar
Kramercd
Did you replace your vvt solenoids?
Old Apr 6, 2020 | 09:12 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Apr 6, 2020 | 11:49 PM
Gabbo81's Avatar
Gabbo81
yes i did i replaced both for fea
Old Apr 6, 2020 | 11:54 PM
Kramercd's Avatar
Kramercd
Only thing I can think of is sometimes when you pull the pins on the tensioners it can move the timing off just a little. Did you replace the chains and guides as well?
Old Apr 7, 2020 | 11:24 AM
Gabbo81's Avatar
Gabbo81
i replaced everything, even upgraded to a m-340HV OIL PUMP,
Snowbunny
21
Feb 7, 2011 09:12 AM
shorebird
18
Jul 4, 2009 11:52 AM
jetdoc
34
Oct 1, 2007 06:13 PM
