Haze at idle
Old Apr 5, 2020 | 11:36 PM
Eaglescout94's Avatar
Eaglescout94
Haze at idle
My truck has been hazing when I’m idling for I’m not sure how long now. My issue is I can’t tell what color the haze it since the only time I see it is at night with a car behind me. The time I noticed it today was when I went to accelerate from sitting at a stop light. I don’t think it does it once it’s fully warmed but can’t tell since there’s no other vehicle around by that time. I rebuilt the engine about a year ago and put a set of full force injectors in at that time my fuel pressure seems to be high, 70, and no clue why it’s that high either. I stopped seeing the haze for a while but noticed it really bad tonight on my way home from work. Does anyone have any insite on what I should start looking at first, and why my fuel pressure is as high as it it? Ive got a stock pressure spring installed and I’m 90% sure it’s not bound up.
Old Apr 6, 2020 | 06:59 AM
timmyboy76's Avatar
timmyboy76
This was mentioned a few years back. Think it's normal. My L99 does it also. During the day, no sign of smoke of any color..but at night, with cars behind me, is when I see it especially get on the freeway
Old Apr 6, 2020 | 10:29 AM
Eaglescout94
That’s good to hear I’m not the only one then
Old Apr 6, 2020 | 11:39 AM
RA101725's Avatar
RA101725
Banned
It’s probably the injectors especially if they are bigger than stock. Mine are stock and haze a little at night if I catch the exhaust in the light just right. At least one of them is in rough shape though so I assume that might be part of it. It comes and goes but not when the motor is cold I notice. I don’t think the fuel pressure is high enough to worry about if that is what you get at idle. It dips a little at WOT. Mine sits around 62-64 at idle and 55-56 is about as low as I can get it to dip on a hard pull.
Old Apr 6, 2020 | 12:59 PM
Eaglescout94
The injectors are 205/80s. I figure I’ll run the truck basically the way it is this year and next I’ll be swapping in a t4 turbo setup to replace the KC38R I have currently. I still have slot of reading to do on the t4 for the bigger injectors but my current setup is the minimum to work with the injectors I have and I’m not a fan of how it’s performing. I’m guessing with the better turbo setup the haze should dissipate somewhat.
Old Apr 6, 2020 | 03:11 PM
Bonanza35's Avatar
Bonanza35
Go to PHP library and try a different tune. Sometimes it is in the tunes as well.
Old Apr 6, 2020 | 11:10 PM
Eaglescout94
The library is only good for stock trucks, once you change pretty much anything you require custom tunes.
Old Apr 7, 2020 | 12:45 AM
FinnishStroker's Avatar
FinnishStroker
Purchase Titan unlock and you can try tunes from PHP extended library.
PHP tune seems to be the cure for my rolling idle issue..
BUT My TC does not lock in third gear with PHP tunes..
Old Apr 7, 2020 | 12:55 AM
Eaglescout94
I will look into the Titan option, thanks for the heads up
Old Apr 7, 2020 | 12:58 AM
Greasemonkee's Avatar
Greasemonkee
I noticed this haze a few days ago, shine a flashlight outward from the exhaust tip at night.
AKPOWERSTROKE
Dec 19, 2011 10:25 PM
Randy777
Sep 9, 2011 07:14 PM
Ringer97
May 16, 2008 07:02 AM
Sand Junki
Jun 27, 2006 07:04 PM
Jaaaaaaackman
May 31, 2006 07:47 AM
